#31
| I found lots of references to flame treatment to prepare PE for gluing and apparently it works. Here is one: http://www.jamestowndistributors.com...t+System+Epoxy My understanding is that heat fusion is fully as strong as the original (for example, fusing pipes). |
#32
| 3M's DP-8005 is also reported to work well. |
#33
| i was an Okoume/epoxy fan for building my catamaran, i found that the plywood 3 mm was easy to work with. this hdpe product is raising my interest. could i buy sheets of hdpe and laminate them with proper glue ? The finish and antifouling "paint" are also a question mark. |
#34
| this guy is making boats out of it and light one too. 3M did develope a special for this stuff but I don't know the Number. I'll come back with a supplier posting. http://www.boulderboatworks.com/bbw_specifications.html http://www.boulderboatworks.com/bbw_specifications.html http://www.professionalplastics.com/...EXLMARINEBOARD and this one http://www.sdplastics.com/marine_board.html |
#35
| I would think that where possible, heat fusing would be better than glue. |
#36
| Anyone have any news on Twintex, there are some beach cats built by Twin Cat in France at our club and they are all ( well ones exposed to the sun) looking like unpainted expoxy carbon parts in that the cloth has come to the surface so nice non skid finish now. They were smooth when they first arrived. How would you fix this? What kind of paint system? Could you treat as per a plastic car bumper ( ppg dpx801?) I have emailed owenscorning and waiting for a reply...
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
#37
| I wonder if you have a PE hull that got damaged, if you could put it back in the roto mill and give it a 'new' treatment...
#38
| the soft heavy roto moulded stuff can be welded successfully. I used one as a tender on a dredge I worked on years ago and we crushed it and did all sorts of things to it. They are very soft compared to later things like I described above which is close to your typical fibreglass weight but you cannot dent it with a sledge hammer with a full swing!
#39
| for a dingy, i plan to build a hovercraft, quite a program. this high density polyet... could be of use. Flamability is a concern but there are treatments and add ons possible. Roxul insulation is one of them. This hovercraft could even house my VW cabrio for beaching a car possibility. There are more reasons for that application, one of them is a <save the planet> reason for building less road infrastructures, i am working on a design for a hybrid elect/hydrogen/unleaded gas craft. of course the car engine's contributes to the <mothership catamaran>. |
#40
At the time my thinking was that a gelcoat on top of twintex would defeat the object of having a boat that was impact resistant. Did the Twin Cat boats originally have a gelcoat finish? Gareth |
#41
| No, they are actually molded with twintex plastic ( off white colour) with twintex cloth inside so I need to prime the twintex so we can paint one. Clearly twintex doesnt really have UV resistance unlike gelcoat Do you know what type of plastic twintex is? Thanks
#42
| HDPE abrasion qualities/weight Quote:
#43
| The Ideal Cruiser - a long range passagemaker | D'ARTOIS | Projects & Proposals | 306 | 07-15-2011 06:54 AM |
| Jet Drive | Jet Drives | 15 | 12-18-2006 09:51 AM | |
| 40-passenger pontoon boat - 2 hulls or 3? | lockhughes | Boat Design | 3 | 07-23-2004 03:04 AM |
| A Tale of Two Hulls.... | BCBoater | Boat Design | 6 | 09-05-2003 01:48 AM |
| Wetted surface area II: Cat hulls or Monos? | Mike D | Boat Design | 1 | 09-25-2002 11:26 PM |
