Old 10-04-2011, 05:37 PM
Flying Flivver's Avatar
Flying Flivver Flying Flivver is offline
Rep: 35 Posts: 37
hull coatings - Graphite Powder mixed with epoxy
can Graphite Powder mixed with epoxy to produce exterior coating be a long lasting and uv resistant hull coating?
Old 10-04-2011, 07:09 PM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
Maybe, but it's not waterproof. It absorbs moisture and can be pulled off with your fingernail after any time underwater.
Kurt Hughes was right about this place.
Old 10-04-2011, 08:34 PM
PAR PAR is online now
Rep: 3125 Posts: 9,403
Graphite thickened epoxy coatings, used on boat bottoms are typically for the really anal racer, that needs to have some kind of edge. Wet sanding with 2,500 grit isn't enough so they try graphite, which does produce a smooth slippery surface, but it really doesn't matter all that much unless the boat is quite small.
As far as it being a long lasting UV inhibiting coating, well no not really. It's better then a straight epoxy coating but still exposes the epoxy to enough UV to break down the surface molecules. As these sluff off under way, new less damaged molecule segments are exposed and the story continues until surface degradation is noticeable.
Old 10-05-2011, 12:43 AM
Rep: 670 Posts: 2,457
Never paint the outside of a boat BLACK....it will attract heat...melt, deteriorate, delaminate, change shape, before your eyes. Graphite power makes a great slippery surface. Not for underwater , but for anything that must slide against itself..like a companionway hatch runner.
Old 10-05-2011, 05:07 AM
gregbond gregbond is offline
Rep: 10 Posts: 4
An unfilled, good quality epoxy resin will have good UV resistance, absorb much less moisture (than filled epoxy) and can be applied to form a smooth layer that can be polished further. Graphite is 'slippery' only due to its' platelike structure - the surface breaks away easilt. Adding ingredients of low surface energy e.g. PTFE. FEP etc is possible, but will add its' own problems - these ingredients will not bond into the epoxy without chemical etching & priming (which is probably not ecenomically viable), they will therefore pull out of the surface and leave pock marks. They will also probably form a rougher initial surface.
Old 10-05-2011, 05:12 AM
FMS FMS is offline
Rep: 125 Posts: 233
I thought epoxy was not UV resistant on its own.
Old 10-05-2011, 05:46 AM
Epoxy is not UV resistant. Either paint it or add a UV filter of Aluminium powder. Best to paint .
Graphite in Epoxy fredrosse Materials 6 08-06-2010 12:15 PM
The end of toxic hull coatings? JonathanCole Boat Design 1 05-29-2009 04:05 PM
What happens when epoxy and polyester are mixed... cornelldave Fiberglass and Composite Boat Building 2 08-21-2006 09:11 AM
Graphite Hulls rturbett Fiberglass and Composite Boat Building 11 10-20-2005 12:50 AM
hull coatings larson Open Discussion: All Things Boats & Boating 1 11-14-2004 04:01 PM
