| ok i only saw him say ground, but cheers for the heads up |
| Patience Grasshopper - this is a time to work slowly to not damage the tile, a small scraper probably would help as well as keeping the cutting edges sharp so they cut the epoxy and not slide around on it. You did not mention how large the spill is but I don't think there are any shortcuts to glory on this one. Good luck, all of us have put epoxy in the wrong place at one time or another - |
| Remove my Daggerboards??? | Imi Loa | Multihulls | 10 | 03-17-2010 10:04 AM |
| How to Remove old Posting | CapeCodAngler | Forum Questions and Suggestions | 4 | 02-14-2010 06:48 PM |
| Remove wood from Fiberglass | cstickman | Fiberglass and Composite Boat Building | 13 | 11-18-2009 06:01 AM |
| What should I remove first, Transom or Stringers? | merrile | Fiberglass and Composite Boat Building | 3 | 07-14-2009 11:00 PM |
| Easy way to Remove Foam? | OGM | Fiberglass and Composite Boat Building | 5 | 10-06-2007 07:25 PM |
