Old 01-07-2006, 07:30 PM
Capt. Chris Capt. Chris is offline
Rep: 10 Posts: 67
How to prep epoxy hull ?
Does anyone have a tried and true method of prepping an epoxy hull prior to applying Duratec VE fairing primer? Had a few problems in the past and need to know if anyone has used this material over epoxy and has some history afterwards. (peeling /checking).. Thanks in advance, Chris
Old 01-14-2006, 09:24 PM
MBW MBW is offline
Rep: 10 Posts: 2
I've never used the Duratec primer but awlgrip (U.S. paints) 545 works well. Its a two part 1:1 epoxy primer that sands like butter. Just block or DA the hull to 150 and your ready to go. Just make sure you sand every square inch!
Newby question regarding Epoxy and fiberglass redecking and plywood choices baranx4 Boatbuilding 3 03-05-2007 08:55 AM
Mods to GRP Hull the big jetski Fiberglass and Composite Boat Building 3 01-23-2006 04:04 AM
SNAME Small Craft Papers CD sorenfdk Boat Design 6 12-29-2005 04:33 PM
