| How Much Wax? Can anyone tell me how many oz. of wax to add per gallon of gelcoat for topcoat? Thanks Swimpy |
| Add about 2%, but a little more won't hurt it any. About 2.5 to 3oz. |
| Thanks much |
| 2% is the correct amount to a 2 qt. pot add about 40 cc's. about the same as mekp. too much takes along time to evaporate and will leave it spoty and possibly crack.when it has cured fully it should look dull but still check in a non obvious spot before starting to sand . |
| you can also use pva to seal the gelcoat after you spray the top coat spray a film of pva over it, this way you will have a less chance of having pinholes caused by the wax sometimes small amounts of wax is traped and when you sand and buff the really show up, duratec high gloss addative is the best for a top coat just add it to the gel and it will lay on flat very little orange peel |
| duratec clear is good but if you are not an experienced painter you will be sanding alot of runs or sags. and partall film #10 {P.V.A. poly vinyl alcohol} could possibly do the same as wax if you spray it too soon.it can dry in mid air and hit the wet paint and put holes in it.Plus you will still wipe the part down anyway the with water and alot of rags. |
| what you mean going though the part with rags and water if thats the case how you sand and buff |
| Pva I believe the previous poster was saying that you need to wash off the PVA with water and rags. PVA is water soluble. |
| Oops--Removing Polyester resin Wax | Fishtale | Fiberglass and Composite Boat Building | 4 | 01-10-2005 10:26 PM |
| Removing polyester Dresin wax | Fishtale | Fiberglass and Composite Boat Building | 0 | 01-08-2005 08:51 PM |
