| Agreed Ondarvr, insufficient wetout would be a concern, regardless of resin system employed. I wasn't picking on you, just trying to be clearer. |
| Yane, by now you know that the problem is caused by faults in the laminate, which you can repair by grinding and filling with polyester. There probably were some particles of wood in the glass mat when you applied the resin. I assume getting a can of epoxy will not be easy in Macedonia, nor is it here. But the guy who sold you the resin and glass mat also has bags of talcum powder (probably from Korcula). Mix resin and talcum until you have something with the viscosity of yoghurt, add a bit of catalyst and paint the whole surface with it. The talcum powder delays the curing process a bit but that's good because temperatures are high already. That gives you a thick, waterproof layer- I call it a Balkan gelcoat - that you can sand and paint if you wish, but you can also leave it like it is.
This Balkan gelcoat idea I like Very much I was considering to first put spry putty and then to put more resin over it, your idea is better. But instead of talcum powder from Korcula I'll use baby powder from Italy, it smells like Adriatic so I'll enjoy the smell of Adriatic sea in my waterproof poly on ply fishing boat fishing on the Macedonian Lakes Thank you for this helpful advice |
| epoxy not waterproof? | magwas | Materials | 22 | 01-15-2010 06:35 PM |
| How do I waterproof the drive axle | klick | Boatbuilding | 15 | 09-24-2008 04:51 AM |
| Waterproof floor leveling compound? | foxmcf | Metal Boat Building | 4 | 04-20-2008 08:06 PM |
| Difference between infusion polyester and regular hand lay-up polyester? | erikssonniklas | Materials | 2 | 01-14-2008 10:48 AM |
| What to waterproof plywood with? | Ward | Boatbuilding | 14 | 06-24-2003 09:52 AM |
