Old 10-19-2011, 01:00 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
How to make BS Granite ?
Hi guys,
I want to know how one makes BS Granite. One of my friends have BS Granite table tops in his houseboat and it looks end feels good !
I know it is made from fiberglass, lightweight.... but how ?
Regards
Fanie
Water ! Just gimme water !
Old 10-19-2011, 01:52 PM
Fanie's Avatar
Fanie
I believe it's also called modular granite.
Regards
Fanie
Old 10-19-2011, 04:25 PM
Flying Flivver's Avatar
Flying Flivver Flying Flivver is offline
Rep: 35 Posts: 37
It is an epoxy aggregate mix made in a hot press or trowled onto a surface, try looking up hand laying resin flooring.
this video was wade by the hover trowel company but it has some usable info
http://www.youtube.com/watch?v=etmFL...eature=related
Another place to look is a company called Granite Transformations
Old 10-19-2011, 07:58 PM
WestVanHan's Avatar
WestVanHan WestVanHan is offline
Rep: 413 Posts: 657
Hi Fanie
I fooled around with this a couple years ago with geopolymer resin binder that contain ingredients I can't spell or pronounce....but is quite expensive. You'd need crushed quartz,feldspar.etc as fillers and it ends up being more expensive than actual stone...but that's too heavy.
The proper term to google is -cultured granite
Old 10-20-2011, 12:25 AM
Herman's Avatar
Herman Herman is online now
Resininfusion.info
Rep: 1043 Posts: 1,269
There are 2 approaches:
-1. use sprayable granite, polyester based. Needs equipment, though.
-2. for the most authentic look, and what they call "composite worktop" over here, use epoxy resin (a durable type) with indeed all kind of aggregates in it. Even pieces of glass or mirrors are used. The mix determines the effect. doable without many tools, but there is a learning curve. I made some parts with that, and the firsts were rubbish. The next ones were ok, though.
Old 10-20-2011, 12:50 PM
rxcomposite's Avatar
rxcomposite rxcomposite is offline
Rep: 746 Posts: 785
Fanie,
I can barely remember the formula but I think it is 30% or 40% resin (low shrinkage) by weight to the granite dust. You can buy granite dust or granules in different sieve sizes depending on the effect you want. All you need is a flat, high gloss table (glass works well) with a dam around the sides to hold the mixture. The mixture is around the consistensy of a peanut butter and the dam can be from 1/2" to 1" thick. Mix slowly by adding the dust so as not introduce bubbles and use a spatula, not a stick to mix it. Pour slowly and even out the mixture. You need a vibrator underneath the table to force the bubble up, 10 to 15 mins. until you are satisfied no more air bubbles are present. Cure for at least 24 hours and always lay it flat after demolding otherwise it will sag. It takes about a week to stabilize. It can be cut with a diamond saw or trimmed with a carbide router.
Granite surface are preferred to be non shiny but if you want high sheen, you can buff it and wax it.
This technology has been around for sometime. Search for "solid surface" in the net. With the basic technique, you can also make marble, tiffany, or other solid surface look. Aluminum Trihydrite (ATH) is the common and easily available material. It was Dupont that made this "solid surface" popular.
I used to cast these "stones" in one of my job.
Old 10-20-2011, 12:55 PM
Fanie's Avatar
Fanie
Hi Guys,
I think the table tops I saw is all composite material.
I have a suspicion the 'granuals' is gellcoat of varying colours and dabbed with a spunge to give it a branular look - or something similar.
Regards
Fanie
Old 10-21-2011, 10:20 AM
Rep: 746 Posts: 785
If it is all composite material, then gel coat of varying hues are deposited to the mold by using an old short brush and brushing through a wire mesh to get the droplets effect. Then a tinted gel coat is sprayed on top and finally the base color which can be as deep a color you want. As it becomes tacky dry, a layer of reinforcing mat is applied then plastic honeycomb or foam core for large unsupported surfaces. Requires skill to do it and you won't get the realistic looking granite.
If you want realistic granite, get the granite dust/granules, mix it with the resin and spray it on. You need special equipment for this but the beauty of this method is that you can make compound surfaces and the product will look like it was carved out of solid granite. Again, you have to reinforce the back side as the coating is very thin. You may have to do some sanding and buffing to expose the surface of the granules.
Old 10-21-2011, 02:27 PM
Petros Petros is offline
Rep: 889 Posts: 1,005
I have mixed something similar as a floor covering, epoxy resin, pigment and med to coarse sand. It is very costly because of the resin costs, better if you mix it yourself rather than buy the "kit". But for counter tops I would think Formica is better, light, cheap and durable, and easy to replace when it gets beat up.
There is a fake rock called Corian, made of plastic resin with some kind of mineral dust. Costs less than the more exotic synthetic counter tops, but more than Formica.
Old 10-21-2011, 04:13 PM
Rep: 35 Posts: 37
you can get corian as thin as 1/4 inch so it fairly light but you have to buy the proper 2 part glue and applicator and clean the joints with at least 95% ethanol befor glueing and use every clamp you've got!
Formica and corian are just brand names it is called solid surface material.
I have made alot of counter tops out of it.
Make of boat grinnindave Sailboats 0 09-08-2009 10:36 AM
Make smother Stason4ik Materials 0 08-23-2009 05:56 AM
granite and marble revolution d.tsalikoglou Materials 0 11-16-2005 11:54 AM
Granite Tops In Boats mark lauzon Boat Design 5 02-27-2005 02:04 PM
How to make a name for yourself ! Tim_Hastie Boat Design 28 06-06-2004 12:14 AM
