Old 12-13-2009, 11:54 AM
jmm4jmc jmm4jmc is offline
Rep: 10 Posts: 3
Hot Water From Manifolds/risers?
I plan on making a simple glassed in or portable 100 gal hot tub. Filled and heated with raw (salt) water. What is the best way to heat the water? The boat is powered by a 350 fresh water cooled/heat exchanger. I only plan to fill/heat it when under way and can just excess can just flow overboard when full. I was thinking of pulling the water from the risers etc. Would this even work without steeling too much water from cooling the manifolds/risers? And would the water even be hot enough? Looking for about 100 deg.
Any other suggestions would be helpful. Did a search but couldn't find an appropriate answer.
Thanks so much,
Jim
Old 12-13-2009, 12:04 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
I know someone that uses the exhaust manifold heat to heat his water with. The exhaust pipe passes through a tank and the water is heated that way. It is fresh water he heats though. A small circulation pump cycle the water through. It works quite well.
Regards
Fanie
Water ! Just gimme water !
Old 12-14-2009, 07:02 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,253
Take the water from the thermostat housing. Use only a 1/4" adapter so enough water is left to cool the exhaust, otherwise you won't be happy in your tub with all the smoke around you.
Old 12-14-2009, 02:04 PM
Rep: 418 Posts: 777
" otherwise you won't be happy in your tub with all the smoke around you."
LOL
Old 12-14-2009, 02:59 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Great idea. You, may want to put a mixing valve in so you can dial in your
temperature by metering fresh sea water with the warmed heat exchanger
sea water. Check first to see what kind of temperature you're getting from
the heat exchanger outlet. You're looking for about 106 F (41C). I think
you'll find it needs to be within a couple degrees of this for comfortable
enjoyment.
-Tom
Old 12-15-2009, 10:32 AM
SamSam SamSam is offline
Rep: 502 Posts: 1,684
If you take too much water from the heat exchanger raw water side, you can overheat your exhaust system. Internal damage like delamination or bulges, especially to rubber parts, is usually hidden from sight or it may be invisible, such as a loss to flexibility or strength or resistance to puncture.
I'm not saying it's impossible to do what you want to do, but I am saying bad rubber on exhaust systems (and I/O transom bellows) is a common cause of boat sinkings. It's not completely secure to begin with, but if you overheat the system once it is suspect.
Old 12-15-2009, 03:46 PM
Fanie's Avatar
Fanie
How does the smoke gets around you ? The exhaust pass through the heater tank and out where it's outside. The exhaust heats the water much better than the cooling system would. Taking water from the thermostat housing is like Sam says, risky for your engine. I wouldn't like to use water in a tub that comes from inside the engine.
Regards
Fanie
Old 12-15-2009, 04:52 PM
apex1
Originally Posted by Fanie View Post
How does the smoke gets around you ? .
The smoke comes from the burning boat!
But with something like 6mm take off pipe there should be enough water left to cool the engine proper.
A "real" calculation would be a better way though.
Old 12-15-2009, 10:55 PM
Rep: 418 Posts: 777
Failing a real calculation, go with a bigger pump!
Old 12-16-2009, 02:55 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Was my message really that cryptic only you understood it Richard?
Having to spell out everything is much less fun.
Old 12-16-2009, 06:37 AM
Fanie's Avatar
Fanie
Whell, there should be a practical side to this as well. How long is a 6mm pipe going to take to fill a tub. This will mean you have to run the motor for a week in advance By the time it's filled the tub is going to be cold again. Nothing encrypted about it, just common logic.
What will work the easiest is to fill the tub and circulate the water around the exhaust and back in the tub. Any time the water gets too cold and you haven't growed finns between the toes yet you can just start and run the circulation again. You want the fastest decent heating with a bit of volumetric flow.
Regards
Fanie
Old 12-16-2009, 10:35 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Splendid suggestion Fanie.
That way he also gets a nice tan, even under his boxer short.
Old 12-16-2009, 10:40 AM
Mariner
It's just dawned on me that another heat exchanger may be the way to go
here. Hot water could be circulated through a copper tube coil in the tub.
Put a valve on it and you've got temperature control. Make that valve a
solenoid and it's auto-magic. Or a combination of plumbing, whatever
works and is easiest and/or simple.
Good luck Jim!
-Tom
Hot water, heaters, cookers..... Willallison Option One 41 11-16-2009 04:59 PM
Where can i get water cooled exhaust manifolds. stika-v6 DIY Marinizing 7 10-12-2009 03:11 AM
Risers hot on one side, other normal chuck hoppe Propulsion 8 03-22-2007 08:12 AM
Hot Water Heater ORION1 Sailboats 8 08-15-2005 07:00 AM
Water Cooled Exhaust Manifolds CPC Powerboats 4 03-30-2004 07:45 PM
