| High service temp reinforcement resin Hello I am trying to find a suitable resin for making steam cylinders from carbon tow. I wish to design for a boiler pressure of 70 bar, saturated steam at this pressure is 285C but it can be superheated, so I guess at least 400C service temperature minimum is required. If I cannot find such a matrix resin, I will start looking for a suitable insulation material for the inside of the cylinder. Maybe a ceramic material could serve as mold, liner and insulation in one? Then I could use a high temp epoxy, such as this one, rated up to 315C. I have seen carbon/metal prepregs with service temps to 700C, but it required vacuuming at 1300C which I am not sure how to do. ps. The title should read "high temp matrix" or something. pps. 500 strokes per minute (equivalent 250 rpm) should be enough. |
as much as I like steam engines in general, as much as I appreciate any new approach in this field, and as much as I am willing to get you supported on your way to find clever solutions, here I like to leave the ring. The engine you are going to install is a clever little invention, but has its main advantage in the low pressure operation. And I am going to build and install such a system myself. The boiler, you try to engineer and build, is by far out of range of what makes sense, in both fittings, lightweight boat and lightweight engine. So, do´nt take it as a personal affront, but I refuse to go that way, no matter if it is possible, affordable or even ingenious. Regards Richard |
| Maybe you are right. I wish to find out. I want to try some oscillating propulsion. That is why the speed is so low. I think it could be built light, but I am not sure. I don't need ceramic inner liner. If I can find a cheap metal cylinder liner, I can mold ceramic around it. Then I can wind carbon/epoxy around that. But I want to see if I can find a different matrix for the carbon. Then I could perhaps use carbon for the piston and rod also. |
| Understand......... |
| Fancy stuff. Is weight most important thing? I have seem some amazing things done with Aluminum. |
| Alum. is a extreme heat conductor, he needs the opposite, regardless of weight. |
| SS Tanks Stainless tanks spheres one within other in a vacumn. Sounds like something Nasa would have built like LOX tanks. |
| no, not a tank,,, a cylinder, containing a piston. |
| Sorry, trying to understand. You want a piston with rod, crankshaft to convert steam to mechanical motion? |
Boiler design and Green Steam Engine I am building one of them too, but three cyl. and low pressure. Regards Richard |
| cool. take lotsa pics, please? The one that struck me as the least likely, is the three cyl. Because the two cyl. looks like it uses a single valve, the four cyl. would then use two valves, but the three cyl. would have to use three! I could end up with two bar and three horses, still be ok. Looking into higher power possibilities for now though. |
| Naturally Sigurd, but it might take a while ´cos I do´nt need the engine before end of the year. It is part of a solar powered off grid generator installation. And I do´nt assemble / machine it myself, I get it done at one of the yards. The Valves are simply two or three way valves I assume. The only reason to go for the three cyl. is, that she is self starting in any piston position. The two cyl. is´nt. Two bar sounds reasonable and easy to achieve. (I go for less than 1 but will enlarge cyl. displacement for increased power) Regards Richard |
| Fibreglass & resin as temp solution to pinhole | Conachair | Metal Boat Building | 4 | 01-20-2009 05:22 AM |
| Thistle Restoration -- Hull Reinforcement | ecka00 | Sailboats | 6 | 06-29-2007 03:17 PM |
| Transom Reinforcement | teel27 | Fiberglass and Composite Boat Building | 4 | 07-08-2006 07:05 PM |
| High-temp Fiberglass | chris7891011 | Fiberglass and Composite Boat Building | 6 | 03-12-2006 08:57 PM |
| Internal keel reinforcement | fishboat | Sailboats | 11 | 10-10-2004 09:09 AM |
