Old 10-17-2006, 08:53 PM
roadking666 roadking666 is offline
Rep: 10 Posts: 3
help with a rotten floor
I just bought a boat, 1984 Larson 5500 Citation, Well, it has a rotten floor, I knew it when I bought it but after taking up the rug I found it was a lot worse than I thought. So, I am reading so much about fiberglass and epoxy resin, I don't know what to use, nor the difference. Can some one explain? thanks.
Old 10-17-2006, 09:54 PM
bilgeboy bilgeboy is offline
Rep: 45 Posts: 157
road king,
Its probably even worse than that. You have to examine the stringers while the floor is out. Poke or prod with an awl, screwdriver, etc, and find the real extent of the damage. I'm not pessimistic, its just that with old boats, its almost always worse than you first think. It will be better than new when you are done.
Let us know,
Mike
Old 10-18-2006, 12:50 PM
asianbandit asianbandit is offline
Rep: 10 Posts: 28
Check this site out
This link is very good, gives you a lot of good information on fiberglass and materials and repair. This site suggests using a different resin than the one recommend on the site. Check it out..it will help..it helped me....
http://capndsboatshed.com/fiberglassmaterials.htm
Rotten Stringers (Tournament Ski Boat) pattyp56 Powerboats 27 09-26-2006 04:51 AM
Rotten Bulkhead - Help!! JoseSanchez Boatbuilding 21 07-03-2006 08:13 PM
Fixing my rotten floor on flats bay boat bronconut Fiberglass and Composite Boat Building 2 05-20-2006 11:00 PM
Help! Rotten Stringers! bhd Fiberglass and Composite Boat Building 24 04-24-2005 05:39 PM
Rotten door bottom Guest Wooden Boat Building and Restoration 2 11-18-2004 07:13 PM
