Old 01-26-2010, 04:19 PM
rrrwel rrrwel is offline
Rep: 10 Posts: 8
help with painted stripping
I have a bridge boat that's 22 yrs old in great condition except for the painted stripping that's so oxidized I can't restore it. The worst one is on the upper bridge, It's a wide grey matallic paint. Covering it with vinyl is not an option.
It's under shrink wrap but everything is accessabile.
A couple things I'm considering but looking for advice.
1. Can I sand and apply just a clear coat? If so, does it need to be sprayed or can it be rolled and tipped. I'll be doing this in the spring under shrink wrap at 50 to 60 degrees.
If I need to repaint, would a simple base coat then clear coat work ok? Again can it be rolled and tipped.
If I need to spray would an HVLP sprayer work? I need to be cautious of overspray.
Any other applications or suggestions are welcome
Thanks for your input
Old 01-27-2010, 07:24 AM
Rep: 1493 Posts: 7,447
I agree with PAR. Clear coating over faded paint will make it shinier but still faded.
stripping off lettering painted over imron Jeff Fiberglass and Composite Boat Building 2 05-17-2009 03:58 PM
restoring a painted crew oar gtviet Wooden Boat Building and Restoration 3 01-07-2009 09:21 PM
Bottom Painted flydog Boat Design 4 04-24-2007 04:10 PM
Painted gellcoat ??? turbo2256b Materials 0 01-28-2007 08:17 PM
Seal and Varnish vs. Painted Boat marcos Wooden Boat Building and Restoration 9 03-11-2004 07:55 PM
