Old 01-18-2007, 04:27 AM
Panos_na's Avatar
Panos_na Panos_na is offline
Yacht designer - Student
Rep: 10 Posts: 60
Help needed for material
Hi everyone.
I need your help.
Please tell me if anyone knows that material are the following :
EU1600
CSM600
DB600
Thank you,
Panos
Old 01-18-2007, 04:45 AM
Panos_na's Avatar
Rep: 10 Posts: 60
I found that CSM means Chopped strand mat.
But I still cannot find anything about the rest.
Old 01-18-2007, 07:51 AM
Eric Sponberg's Avatar
Rep: 2547 Posts: 1,426
Originally Posted by Panos_na View Post
Hi everyone.
I need your help.
EU1600
CSM600
DB600
Thank you,
Panos
The most likely the translation is:
EU1600 = E-glass Unidirectional, 1600 grams/sq. meter
CSM600 = Chopped Strand Mat, 600 grams/sq. meter
DB600 = Double Bias (+/-45 deg weave), 600 grams/sq.meter
These appear to be European designations, so someone in Europe may correct me.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 01-19-2007, 12:59 AM
Panos_na's Avatar
Rep: 10 Posts: 60
Thank you very much!!!
It was very helpful!!!
Old 01-19-2007, 01:33 AM
Panos_na's Avatar
Rep: 10 Posts: 60
Also, does anyone know about a material named Aramat 72k/200 0/90o(degrees) ??
It would be very helpful too, if someone could explain the numbers.
thank you.
Old 01-19-2007, 02:41 AM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Well...
Ara- aramid? Mat- mat? 72k- fibers per yarn? 200- areal weight (g/m2)? 0˚/90˚- fiber orientation in fabric?
Old 01-19-2007, 02:45 AM
Boatbuilder
Rep: 15 Posts: 545
Eric,
Just to be a petulant arse,
DB probably knitted rather than woven.
Old 01-19-2007, 03:24 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Some info from AMT (Devold) a Norwegian supplier,
Overview
http://www.amt.no/products.asp?page=1607&lang=2
DB:
http://www.amt.no/files/documents/gl...ts.biaxial.pdf
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 01-19-2007, 09:24 AM
Originally Posted by yokebutt View Post
Eric,
That's what I meant. You use these designations enough and you start getting sloppy in the designations. DB is a double bias fabric that is knitted together so that the layers of fiber lay flat against each other.
Thanks for the correction.
Eric
Eric W. Sponberg
Naval Architect
material help please madmatt Boat Design 2 11-30-2006 07:56 PM
Material help Negroo Materials 0 04-03-2006 08:42 AM
boat material / furniture material bogeyinthekeys Materials 7 09-10-2005 08:29 AM
material bevan Boatbuilding 4 10-15-2004 04:21 AM
Best Material Aquaholic Boatbuilding 1 09-25-2004 05:27 PM
