Old 09-14-2007, 07:34 AM
patrik111 patrik111 is offline
Rep: 10 Posts: 41
Heatforming foam to compound curvature
Hi,
Is it possible to heatform compound curvature using corecell/Airex or similar foam core material?
If so, to what extent?
My purpose is a female stringed mould with termoformed foam for a beachcat hull. But avoiding the horizontal stripping.
All input is greatly appriciated
Patrik Elfving
Old 09-14-2007, 07:50 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 604
Corecell according to their literatore is "Highly Thermoformable"
http://www.fram.nl/faq/how/Corecell_Brochure.pdf
I've seen it on hulls formed to some pretty tight curves. Probably a radius of less than a foot.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 09-14-2007, 08:52 AM
Rep: 10 Posts: 41
Compound curvature
Hi,
What I am looking for is compound curvature, i.e. bent in two directions at the same point.
The material I find in brochures etc indicate bending in one direction. To a certain extent, it seems to be possible to bend in two directions, but I have no data on how tight radius might be possible.
BR
Patrik Elfving
Old 09-24-2007, 07:55 AM
Rep: 10 Posts: 41
It is possible!
Heatforming Airex to compound shapes is possible. Although the radii possible is quite much larger than possible if curved in one direction only.
BR
Patrik Elfving
Old 11-19-2007, 03:27 PM
lighterisfaster lighterisfaster is offline
Thermoforming Corecell
Hi patrik111
Please contact me at andrew.bellamy@gurit.com and I will be happy to forward you a copy of the Corecell Thermoforming Guide.
Best regards
Andrew Bellamy
Composites Processing Manager
Gurit (Corecell)
Old 11-20-2007, 09:04 AM
kengrome kengrome is offline
Rep: 287 Posts: 719
Hi Andrew,
Maybe you can post it here so others can download and review it too ...
Kenneth Grome
Old 11-22-2007, 06:56 AM
Rep: 700 Posts: 3,208
We have heated Airex into simple (33ft boat) compound curves with a duct from a normal home hot air furnace.
The wall thermostat was paralleled with an of-on switch and the foam placed in a wide duct for a few min.
Gloves are needed to remove the Airex and it was placed on the male plug and simply rubbed to get the shape.
As with most Airex construction the sheet was fastened to the plug by sewing with a needle and heavy thread.
After the outer skin was laid up the threads were slashed after the hull was rolled upright , and installed in a "keep the hull shape cradle".
Nice method for one or two boats , but the hassle of long boarding the outer surface to acceptable yacht finish is long and very labor intensive (and boring)!
I have seen builders that used a hot water tank , and weights to hold the Airex submerged to heat it.
FF
Gaussian curvature Nojjan Boat Design 11 08-18-2007 05:40 PM
freeship and curvature dionysis Software 2 06-10-2006 05:21 AM
fairing compound HWL Fiberglass and Composite Boat Building 18 03-19-2005 02:05 AM
Plexiglass maximum radius curvature nico Boat Design 2 05-22-2003 03:03 AM
Maxsurf Curvature question ErikG Software 4 03-18-2003 03:30 AM
