Old 07-31-2011, 05:00 PM
Fishbone Fishbone is offline
Rep: 10 Posts: 5
HDU Foam Board?
Hello Everybody.
New to your forum and have a few questions to throw out there for anybody that has legit answers.
Thanks
Am currently rebuilding my 1994 Hewes LT20.
Hit a submerged log a few months back and ended up with a couple of leaking cracks in the hull.
It was later discovered that the stringers are in need of replacing, which is where I am at with the rebuild.
My question is?
Is (HDU) High density urethane sign foam the same material composite companies are selling for building boat stringers?
HDU sign foam is closed cell, comes in 4-40# pvc strengths, is mold resistant, water proof, etc., etc.
From what research I have come up with I'm under the impression I should be using a minimum of 26# HDU foam board for my stringers, 1708 Biaxial woven mat and epoxy resin.
Are these the correct materials I shoud be using for the stringer and bulkhead replacements?
New designer on board kroskris Open Discussion: All Things Boats & Boating 22 01-04-2011 04:30 PM
ALL-A-Board rapscallion Fiberglass and Composite Boat Building 0 04-02-2008 09:49 AM
Center-board r.mike Boat Design 2 01-21-2008 07:55 PM
Pets on board gonzo Open Discussion: All Things Boats & Boating 13 05-03-2006 05:19 PM
Composite foam board sandwich technique scottperkinsusa Boat Design 11 09-18-2004 08:30 PM
