Old 01-14-2010, 02:38 PM
lascraigus lascraigus is offline
Rep: 10 Posts: 24
HDPE hull material
Can High Density Polyethylene be used as a well suited hull material for a 21 ft boat?
Old 01-14-2010, 02:52 PM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
Let's see now. Heavy, flexible at normal temperature, breaks at low temperature and weaker than most other competing materials. Did I mention heavy. Makes good fuel and water tanks.
Ok, its possible to make boats with HDPE but not for me.
Tom Lathrop
Old 01-14-2010, 02:55 PM
Rep: 10 Posts: 24
There is a company in Australia that has successfully made two 30' conventional hull powerboats out of this material.......I wonder how they pulled taht off from all the negative things I have heard about it's use as boat building material.......hhhmmmm.
Old 01-14-2010, 03:40 PM
jonr jonr is offline
Rep: 34 Posts: 246
Triumph seems to think so and their weight is in the range of other materials. And I've banged a HDPE boat around on ice with no problems.
Old 01-14-2010, 04:07 PM
M-Sasha
That is a lie! No, two lies.
HDPE is substantially heavier than wood or GRP for a given strength. (and even then a very bad choice)
And you did for sure not bounce around on ice with a HDPE boat.
You have already been asked if you have ever seen a boat.
May I ask again here: have you ever seen a boat jonr?
Why are you commenting exclusively on topics you have absolute no idea about?
About the "success" I have my doubts, but anyway, you asked for a sailboat or not? And apex asked where would you attach the loads from rigging and a keel, or not?
So, where?
I will tell you: nowhere.
Build yoor tanks from HDPE if you must.
Sasha
Old 01-14-2010, 04:14 PM
Rep: 10 Posts: 24
Please see this:
http://www.vimeo.com/7260551
Old 01-14-2010, 04:20 PM
Rep: 10 Posts: 24
might want to fast forward to 1:45 or so if you do watch it......once the whole Meyerson symphony orchestra starts its thing the video kinda drags for a bit.
Old 01-15-2010, 04:01 AM
nukisen's Avatar
nukisen nukisen is offline
Rep: 114 Posts: 383
Why not use epoxy instead?
The more I learn the more I do understand that I do not understand. :)
Hulls made of HDPE Baldur Materials 42 04-21-2011 12:55 AM
HDPE Boat Hulls kach22i Materials 6 03-21-2009 12:21 PM
hdpe hull strip planking /molding gabdab Materials 18 11-15-2008 02:00 PM
HDPE as a boat hull material JonathanCole Boat Design 14 06-14-2007 02:15 AM
Designing a 25-30ft boat with a HDPE hull mattosmond Projects & Proposals 28 02-12-2007 03:58 PM
