Old 08-05-2010, 06:38 PM
fredrosse's Avatar
fredrosse fredrosse is offline
USACE Steam
Rep: 29 Posts: 55
Graphite in Epoxy
Has anyone actually had experience with this? I was told it will make the bottom of my new plywood boat less likley to get pierced during grounding.
The bottom is plywood, already coated with epoxy and 9oz cloth.
Thanks for help
Old 08-05-2010, 06:57 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1874 Posts: 3,357
Kevlar is resistant to piercing.
Hoyt
Old 08-05-2010, 09:31 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,598
Thanks for help
I think you're thinking of woven carbon fiber-not a whole lot of help in thin layers for your purpose-and very expensive.
Like Hoyt said Kevlar would probably be better but not as a final layer-it does not like abraision. If you sanded the bottom and went thru to the kevlar it fuzzs up and is very difficult to fix cosmetically. A layer of glass over the kevlar might be a good idea.
Unless you're going to be frequently grounding glass is likely to be ok.
yes, it is a revolution
Old 08-05-2010, 10:18 PM
Scrumble's Avatar
Scrumble Scrumble is offline
Oram 46'C MS Builder
Rep: 75 Posts: 41
Mix graphite powder with silica (Cabosil, Aerosil) in epoxy and coat the bottom, this resulting very hard, very slippery and very black surface, is used for protection on anything where there is occasional rubbing of one sort or other. It can be used as a large area bearing surface... LOL ie. bottom of your boat, where if it rubs through there will be an obvious colour change.
See http://www.westsystem.com.au/west_sy...raphite_powder
Tom
http://scrumbleproject.wordpress.com/
'No shortcuts for a vehicle from which you cannot get out and walk'
Old 08-06-2010, 12:39 AM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
Graphite mixed with epoxy reduces water resistance when submerged over time. Don't do that on the bottom. It is primarily for lubrication when mixed with epoxy. Hoyt has it right. Kevlar, though heavy, is for strength in groundings.
Kurt Hughes was right about this place.
Old 08-06-2010, 04:34 AM
Herman's Avatar
Herman Herman is online now
Resininfusion.info
Rep: 1043 Posts: 1,269
Kevlar heavy? It is less heavy then glass... Actually we should be talking about aramide, to give Teijin Twaron also a chance...
Also, aramide is highly resistant against abrasion. It will turn into a mess, but will not get penentrated.
There are also rubbing pads from materials like UHMWPE, which are frequently used on RIBS which get beached frequently.
Old 08-06-2010, 12:15 PM
apex1
There is another point to be noticed!
Graphite is noble to everything!
Take care you donīt invite galvanic corrosion when using graphite under water.
Regards
Richard
epoxy 17 bucks a kilo epoxy freight included! nukisen Materials 32 04-10-2010 01:51 AM
epoxy,epoxy, opps flooring epoxy aboyd Materials 5 09-12-2009 02:56 PM
Graphite Hulls rturbett Fiberglass and Composite Boat Building 11 10-20-2005 12:50 AM
Graphite CAD users? JasonR Software 18 10-12-2005 10:03 AM
Curves in Ashlar Vellum Graphite CaptPKilbride Software 0 09-22-2004 07:54 AM
