| Gelcoat spraying What is the minimum size of the nozzle to spray gelcoat in the boat mold 2.5 mm ? or 4.0 ? i am loking to buy this http://stores.infinityfrp.com/-strse...gun/Detail.bok or http://stores.infinityfrp.com/-strse...Gel/Detail.bok or http://stores.infinityfrp.com/-strse...oat/Detail.bok or http://stores.infinityfrp.com/-strse...oat/Detail.bok |
When you spray gel coat find plastic containers to fit inside to hold the gel coat or paint !! Can catalyze!,mix and then place into the pot and put on the lid and tighten and then spray . The plastic container is one thing less thing you will have to clean . wait till has gone hard and break out !!and you container is ready to ues again , if you are carefull the container will last long time . If it is not clean 100% will show you the catalyst was not mixed Properly If you have never used a pressure pot before carefully read the instructions before you start to use so you completely understand how it works and what everything does . Star with all pressure setting at 0 psi slowly wind up the pot pressure then set th gun air pressure to about 35 psi and adjust the pot pressure till you get a flow then adjust needle on the gun and the fan setting to get a nice spray . Gell coat you are looking for product on the job bu also good spray . Takes time to learn . Also need a egg timer to set when you catalyze the gel coat !,The timmer will tell you when it is time to flush ,clean out the pot, lines, and the gun . Can spray almost anything with a pressure pot . Keep it totally clean always !!will last you a life time ,. dont need anything else !! ![]() The G 100 spatter gun is the crudest gun any one can think of apart from throwing a bucket of catalyzed gel goat at a mould . I did see some one advertising a external catalizing gun the same as the G100 but with a external catalyst spray unit on the side . In the hands of a beginner thats got to be a time bomb !!! The D660 is a gravity feed touch up gun Meant for smallish jobs with thinned gelcoat or runny paint etc etc The G960 is a smaller version of the big pressure pot works the same just on a smaller scale . If you can find a good secondhand one grab it . I have adapted all my fittings to Quick release off my G960 /9 LTR pressure pot to hook straight onto my G960 SMALLER 2.5 LTR so when i want to do a speckle coat job or spray a small job of less than one meter sqr/meter i just use the small unit with a plastic container and drop it inside the Small pot !!
| i can do al with za 2.5 nozzle ? its not to small ? |
| I just looked at your location and you get lots of cold weather so will need a bigger nozzle as well as the smaller one for the summer months . When gel coat gets cold it becomes quite thick . You have two choices !!,you get the place and the gel coat warm or thin the gel coat a little with acetone or styrene to make it spray out of the gun better . But if you thin the gel coat you will have the gelcoat changing colour slightly .Getting everything warm is much better option !! ![]()
| Can i buy a bigger nozzle maybe for the spray gun for this one http://stores.infinityfrp.com/-strse...oat/Detail.bok Yes here it will be cold and i think we will do with gelcoat in one or two months, so it will be more colder |
Looking very closely at the gun and pot , The regulater on the pot is only to change the pot pressure . so full air pressure goes to the gun all the time . Is good to be able to regulate the gun air to cut down on the amount of over spray going all over the place need regulator valve fot the air line to the gun as well . Tooling gel coat application Check out this post on Boat design this is a place i posted some pictures of 2 pressure pots ( one big 9kg and one small 2-5 kg )i made myself from just old parts in in boxes in our store room , it Can give you idea what i am talking about !! ![]() ![]()
| i saw that, nice what type of gelcoat are you using? i was looking satajet and they prefere nozzle 4.0 5.0 but the gun and all cost 1300 € it is to much many of people i ask in croatia they say i need a bigger nozzle but i was looking in USA on some forums all they use 2.5 If i use 2.5 i need bigger pressure than when i do it with 4.0 ? thx |
| We have just standard gel coat ! small jobs we use a pressure pot !! big decks and hulls we use a venus gun with inline heater and internal mix catalyst , The 48 foot deck takes about 80 minutes to spray . It makes nice job but the guys have not got used to using it yet . Has small nozzle or they get runs every where all the time !! The best for your new pot would be to get small nozzle for paint and big nozzle for gel coat then you are covered for all situations
| i have to do a 24 ft hull mold how many gelcoat i have to put on the mold in mm ? |
| spraying gelcoat | toolsinbox | Boatbuilding | 0 | 01-16-2010 06:43 PM |
| spraying gelcoat | gethookedjr | Materials | 3 | 03-07-2007 01:51 PM |
| Spraying gelcoat | Sunfish52981 | Fiberglass and Composite Boat Building | 1 | 04-23-2006 08:29 AM |
| Equipment for Gelcoat spraying? | Johan Linder | Fiberglass and Composite Boat Building | 3 | 10-20-2004 09:32 AM |
| Spraying two color of gelcoat | goodwrch | Fiberglass and Composite Boat Building | 4 | 05-23-2004 12:42 AM |
