Old 05-17-2009, 06:31 PM
cme4pain cme4pain is offline
Rep: 10 Posts: 12
Gelcoat nightmare
I was patching up last years gouges and scrapes on the front of my boat.
Sprayed evercoat brand gelocoat over the repair area thinned with 10% acetone. Certain parts of the gelcoat didnt catalize. Thinking I screwed up mixing, I took it off mixed up another batch and mixed with my drill attachment, thinned and resprayed. Same problem.
Can it be that I used colloidal silica in my fairing compund, gelcoat not compatible with epoxy. I cant think of anything that would cause the gelcoat to catalize in some areas and not others.
Old 05-17-2009, 07:14 PM
Fanie Fanie is online now
Fanie
Rep: 1056 Posts: 3,599
Which catalist did you use and what ratio. What you describe does not make sense. If you add catalist to gell coat it is supposed to harden correctly. Done it many times, just never thinned it.
I'm not too sure about thinning the gell coat with acetone though, I've never done that.
Regards
Fanie
Old 05-17-2009, 09:06 PM
Rep: 10 Posts: 12
manufacturers instructions said thin with acetone 10-15% to spray. Catylist came with the gelcoat. Quart size can I mixed a pint and used half the catylist per instructions. Its weird. On one hand I have a beautiful gelcoat but in some areas it just didnt set. Areas about the size of your hand. Thats why I am wondering if the silica in the fairing has something to do with it. But even that makes no sense. If the silica had something to do with it it probabaly would fisheye like an automotive paint or just not adhere.
Old 05-18-2009, 01:52 PM
MikeV MikeV is offline
Rep: 10 Posts: 14
what type of gun did you use to spary just wondering...
spmtimes i end up spraying over it with a mixture with more hardener ????
Old 05-18-2009, 03:28 PM
Rep: 712 Posts: 4,560
Is the gelcoat waxed?
Old 05-18-2009, 08:47 PM
Rep: 10 Posts: 12
no no wax. Sprayed with my gravity gun. I am gonna mix up another batch tomorrow from another brand.
Old 05-18-2009, 10:56 PM
mark775 mark775 is offline
Rep: 479 Posts: 722
You could put a little acetone in there but what manufacturer recommended that? Generally they have thinners specifically for that. It has been done for as long as there has been gelcoat but it doesn't even make sense, as I understand the chemistry. People used to thin with acetone to get it to partially soak into plywood which doesn't do anything. The colloidal (fumed) silica didn't hurt anything unless it was contaminated. I don't understand adding it to the gelcoat to spray, however. Was it recommended to build up faster or prevent sagging, or what? I wouldn't. RU a dentist?
Old 05-18-2009, 11:00 PM
Gelcoat with no wax will not cure. It is air inhibited.
Old 05-19-2009, 03:29 AM
Rep: 479 Posts: 722
Gonzo is right, of course. We all missed that.
Old 05-20-2009, 07:38 PM
Rep: 10 Posts: 12
what wax? there is nothing on the can that says wax. I didnt add silica to the gelcoat. I mixed silica in with my epoxy resin for my repair and sprayed gelcoat over it.
Old 05-20-2009, 11:38 PM
Rep: 755 Posts: 1,629
Gelcoat over epoxy, NO.
You can epoxy over polyester, but not popyester over epoxy. and there should be waxed gelcoat for top coating , known commercially as Flocoat. It is simply gelcoat the has wax in styrene mixed in, it allows the air ti be sealed from the surface and the surface can cure.
"I am not a complete idiot....some parts are still missing!"
Old 05-20-2009, 11:42 PM
They sell the wax solution to add to gelcoat. Epoxy produces amines when cured. I don't know how it could affect the gelcoat.
Old 05-21-2009, 12:27 AM
ondarvr ondarvr is offline
Rep: 78 Posts: 383
You have two things that may have happened.
1. No wax in the gel coat, this will cause the surface to stay tacky, but you should be able wipe it down with acetone to remove the surface and then sand and buff it as normal.
2. The epoxy was still curing and inhibited the cure of the gel coat.
The bigger issue is that even if it did cure well and you finished the job, it may not hold well. Polyesters just don't bond that well to epoxies, it will stay in place for a while, but the chance of having problems in the future are much greater than when using compatible products.
Old 05-21-2009, 03:31 PM
Rep: 10 Posts: 12
Thank you! I figured it had something to do with incompatitable materials. I did wash the uncured spots down with acetone. Guess I will sand the epoxy out and redo with polyester resin.
Old 07-09-2009, 10:14 AM
thill thill is offline
Rep: 10 Posts: 26
...Or just use a barrier coat?
Floating nightmare Callinectes Stability 46 06-15-2007 07:38 PM
Gelcoat help pappastratos Boat Design 0 06-19-2006 11:02 PM
Spraying gelcoat over gelcoat alexhiguera Open Discussion 9 08-26-2005 10:09 PM
stripping (nightmare) ? GarveyGuy Wooden Boat Building and Restoration 6 07-24-2005 09:58 PM
My Chinese Nightmare prcmike Wooden Boat Building and Restoration 10 07-23-2004 11:57 PM
