Old 02-03-2011, 12:21 AM
wrbowcal's Avatar
wrbowcal wrbowcal is offline
Rep: 10 Posts: 22
Gelcoat mixing additves?
First off I don't know much about gel coat just a couple vids on utube.I need to know what I was told by the kid that sold me my supplies is correct for application as I don't want to loose over $500 doing it wrong.I will do my best to try and explain this.what I have is 2- 5gal pails half full of white gel coat, lots of MEKP and 1 pint of what he calls air dry?....told for the first coat mix acetone to thin then the catalyst(MEKP) to the gel coat mix and apply,He said it will not go hard just tacky.Then for the final coat(the other pail)add the pint of air dry into the 2.5 gal then acetone then MEKP and this will harden the tacky first coat when set.
I just purchased a 2qt canister sprayer that has a 1.4mm and a 2mm nozzle cheap a little over a $100.00,not professional equipment but I hope it will do the job.Does this recipe sound OK? No writen instructions on anything all poured from bulk containers? Oh can I mix the MEKP to the same ratio as poly resin at 100 parts to 1 for min approx 1 hour before it starts to harden I can get the shop up to about 70 deg .thanks
Old 02-03-2011, 12:57 AM
mark775
There are those here that are better qualified than I to guide you but there is much that is wrong with this plan. Wait a day, at least, there are many eager to help with this. To start, I don't believe you should thin the first coat with acetone. The first coat does harden - it's just that the outermost links to oxygen molecules. The "air-dry" has to be a brand of surfacing agent - it keeps the oxygen from the surface and forces the linking to happen to each other, rather than oxygen, thus a hard surface. Yes, use a cheap sprayer. Don't mix large batches or it will kick from its own heat and disappoint. Work safe, there are some bad chemicals there.
Old 02-03-2011, 08:00 AM
idkfa idkfa is offline
Rep: 66 Posts: 232
thin with styrene and not acetone, and no more than 10%.
Old 02-03-2011, 10:01 AM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
How you plan to use the gel coat will determine the spray equipment and methods. What is the project?.
It sounds like you plan to spray a large surface ???
From your description of the spray gun I can't tell if its a siphon gun or a pressure pot?
Thinning is not recommended, but is done at times, it depends on the project and what you want as a final result.
Air Dry is a regional term for surface agent, it is wax dissolved in styrene.
With a little more info people here should be able to walk you through it
Old 02-03-2011, 10:07 AM
pescaloco pescaloco is offline
Rep: 67 Posts: 243
Typically gelcoat is catalyzed at 1.5 to 2%
Use the 2.0mm tip for your sprayer the bigger the better
Thin with Styrene or MEK they say 10% but reality is with your spray equipment you may need to go a little more (but you degrade the gelcoat some by thinning)
I think you will be in big trouble if you mix / catalyze 2.5 gallons of material at one time. AT 70 degrees F and 2.0% catalyst you have aprox. 30 minutes to work, that means spray your material and wash the gun out.
The surface seal is a paraffin wax in solution with Styrene, set it in the sun before you use it and shake it up well. Add to final coat at around a 5% ratio or what ever ratio your supplier stated and make sure to mix it in very well with your gelcoat
Old 02-03-2011, 12:31 PM
wrbowcal's Avatar
Rep: 10 Posts: 22
Alright,Ok I will buy styrene for sure for thinning and just thin to 10% .The spray gun is a pressure pot gun with 2 hoses 6ft long that go to the 2qt canister 45 psi max so I have to thin to spray.I have a couple HVLP guns I can use for above the water line. The project is to gelcoat the new stringers, ribs,bilge bulkhead and floor (Just one coat),and the hull under the water line on my bayliner 2750 (2 coats).I hope I have enough gelcoat? To prep the hull would I sand with 80grit? I need a supplied fresh air system Im sick as a dog from glassing the stringers yesterday even with a fan,respirator and tyvek coveralls didnt help?
Gelcoat mixing additves?-boat-jan-30-002.jpg  Gelcoat mixing additves?-boat-sept-6-2001-017.jpg  Gelcoat mixing additves?-boat-jan-25-003.jpg
Old 02-03-2011, 01:41 PM
Rep: 1493 Posts: 7,447
Acetone is really a bad choice for thinning. Styrene is somewhat better. If you want a good product, use Durated Clear additive. The last coat of gelcoat needs wax, because it is air inhibited. If you let it open for too long, it will absorb humidity and become a sticky mess. With Duratec you donīt have that problem
Old 02-03-2011, 05:29 PM
Rep: 67 Posts: 243
You may find it easier and faster to just use a roller to Gelcoat the above mentioned parts of the boat.
If you are not aware the gelcoat you spray that you probably want to shine and look very smooth like you see on a new boats hull will not be achievable by spraying. You will need to sand out all the orange peel with progressively finer grits of paper then polish out with a buffer and compound. If you don't care cool or if you already know my apologies
Old 02-03-2011, 05:35 PM
Rep: 288 Posts: 662
For the bilge its not going to make much of a difference on what mix you use, but you will need the surface agent (air dry). I typically just roll the bilge and floor areas, spraying can be messy, dirty (over spray) and stressful when new to spraying gel coat.
Air dry is just styrene and wax, so adding it is just like adding styrene to thin it.
Adding anything to thin gel coat will degrade it, typically it reduces the weather, crack and water resistance, so whatever you use, add as little as possible.
Old 02-04-2011, 09:34 AM
wrbowcal's Avatar
Rep: 10 Posts: 22
I looked for styrene today and could not find it in the small town Im from but will get it.acetone is not an optioin now, just for cleaning the gun and pot. Hey! rolling the interior is what im going to do it will save a huge amount of time masking etc.Thanks for the tips.
1978 Bayliner Victoria 2750
Old 02-04-2011, 05:21 PM
Rep: 288 Posts: 662
Remember, your air dry is styrene with wax in it, so you do already have styrene, but add as little as possible, because styrene will degrade the gel coat too.
Old 02-04-2011, 08:07 PM
Rep: 67 Posts: 243
You can use MEK to reduce your gelcoat for spraying
Old 02-05-2011, 02:06 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
I got a pretty good sence of humor but this takes he cake and the tray !! Where do these peole come from ????
Making beautiful boats is a passion never a chore !
Old 02-05-2011, 06:54 AM
Rep: 66 Posts: 232
I'm at a lost here, MEk v Mekp? but.... no anyway!
Maybe you could use a little resin to thin with if no styrene is available.
Old 02-05-2011, 08:09 AM
Rep: 288 Posts: 662
MEK is a solvent and is totally different than MEKP (catalyst). Some people do use it to thin gel coat, I don't use it, but it does have a history in the industry.
Mixing similar designs Paul No Boat Boat Design 2 02-12-2010 03:29 PM
fish eyes when mixing with duratec discopimp Boatbuilding 1 03-25-2009 07:54 AM
Mixing aluminum and fiberglass on a bass boat? northrivergeek Fiberglass and Composite Boat Building 8 11-09-2008 02:28 AM
Mixing metals underwater fisherJim Boat Design 16 10-02-2007 07:57 AM
How make fillers mixing much easier? jfblouin Materials 16 09-25-2005 12:51 AM
