Old 05-13-2011, 04:51 AM
Hunter25 Hunter25 is offline
Rep: 46 Posts: 173
Fumed silica substitute
Can corn starch be used as a silica substitute? It would be a lower cost thixotropic additive in alkaline mixtures like epoxy. Would is also impart the adhesive properties that silica has? Would wheat or corn flour be as effective as wood flour as an additive? Wood flour is common in fillets, just looking for an inexpensive substitute. Any other filler substitutes?
Old 05-14-2011, 08:58 AM
Rep: 1493 Posts: 7,447
No. Silica has a very low humidity content. Wood flour, unless it comes from a species that is low in oil and rosin can be a problem too. Silica is quite cheap, also it is thixotropic as you say. Other fillers, including wood flour, are not. That makes for a drier mix.
Old 05-14-2011, 03:02 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,055
Yes it can be used, but isn't as good as silica. As wheat or corn flour instead of wood grit. You can use pretty much anything dry enough with epoxy but you don't know how it affects to the physical properties of the mix, so better stay with known additives..
Old 05-14-2011, 04:05 PM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
Buy your silica nearby from bateau.com in Vero Beach. It costs next to nothing.
Kurt Hughes was right about this place.
acetone substitute tropicalbuilder Fiberglass and Composite Boat Building 29 07-24-2011 08:38 PM
Aerosil (Cabosil) fumed silica is hydrophillic (readily absorbs water)? naturewaterboy Fiberglass and Composite Boat Building 2 07-25-2008 10:29 PM
Substitute for Oregon Wood Boat Wooden Boat Building and Restoration 3 03-26-2007 09:08 PM
Can I substitute Honduran Mahogany? Swimpy Wooden Boat Building and Restoration 6 08-04-2006 08:11 PM
Usage of microsphere, microballoons and silica miss dynamite Fiberglass and Composite Boat Building 1 05-08-2005 02:57 PM
