Force required to bend plywood panels
richardf
Joined
May 7, 2013
Messages
44
Reaction score
Location
Michigan
The following technical documentation specifies minimum bend radius for various thichknesses of ply wood panels:
http://www.schmeling.com/reference/pdf_files/plywood_bending_radius.pdf
Of interest would be the force required to achieve these bends as a function of panel width. I would think it is a linear function with width. I also suspect that bending a 4 foot wide sheet of 3/4" plywood to a minimum radius of 12 feet will take a very large force (like in come-along territory). I wonder if bending a 4 foot wide panel of 1/2" ply to a radius of 6 feet, requires the same force? I suspect it does.
depends on lever length as well, doug fir plywood has an elastic modulus of about 1.0 to 1.2 x 10^6 psi, if you work out the geometry you can likely work out a force for any given width of plywood.
4 foot will take more force ....
  • Back
