Old 06-30-2006, 06:13 PM
pairomedicsfish pairomedicsfish is offline
Rep: 10 Posts: 12
Foam for Insulation, not structure
What types of foam can I use to insulate fish boxes? they will be constructed of ply under glass, but I will need to lay up a foam layer. I cannot use expanding foam, since thee is no dead space for it and the faom needs to be flat to lay glass over.
Old 07-02-2006, 07:07 AM
Rep: 10 Posts: 12
Even a little help would work.
Old 07-02-2006, 08:34 AM
hansp77 hansp77 is offline
Rep: 200 Posts: 691
cut and fitted styrofoam.
Free, easy.
But then of course there would be many other options as well.
Old 07-02-2006, 09:54 AM
Rep: 10 Posts: 12
Regular styrofoam will melt after the appliocation of polyester resin. The Pink insulation foam fro Hoem Depot will also melt. I need something that will not melt. But thanks for the reply......
Old 07-02-2006, 10:39 AM
SamSam SamSam is offline
Rep: 502 Posts: 1,684
You need the polyurethane stuff from Home Depot which is brown colored and covered with foil or you can go to an insulation supply company and get some polyisocyanurate foam that is used on roofs, usually commercially. The polyiso comes in different thickness's and is somewhat structural as they have to make it tough enough to walk on. I've made 4x4x4' fishboxes with just it and no ply. Cut to shape and either pin together with wire or nails or tape with metalic foil tape like used in AC ductwork and then glass. Sam
Old 07-06-2006, 08:28 AM
antonfourie antonfourie is offline
Rep: 13 Posts: 169
Or use epoxy over styrofoam
aluminum interior insulation Metal Boat Building 28 02-06-2006 06:54 PM
thinsulate sound insulation nilo Open Discussion: All Things Boats & Boating 12 02-15-2005 02:31 PM
insulation for sale AAllen Marketplace 1 01-10-2005 03:45 PM
Insulation Alex Hall Materials 4 12-04-2003 04:53 PM
insulation Materials 0 11-16-2002 03:24 PM
