Old 07-29-2002, 01:13 AM
Willallison's Avatar
Rep: 2283 Posts: 3,468
Foam core thickness and density
Here's a "how long's a piece of string" question for you...
Can anyone give me an estimate of thickness and weight (kg/sq.m) for foam core panel required in the construction of a 30-odd foot powerboat.
I have 2 boats in mind - Option 1, some details of which can be seen in its own thread on this web site.
The other is about 11m LWL, 3.7m beam, displacement 5000kg, top speed 30+ knots, inboard power.
I only require the info for rough weight estimates at this stage.
Even better - an on-line source of where I might be able to work this stuff out......
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 07-29-2002, 02:49 AM
BrettM's Avatar
BrettM BrettM is offline
Rep: 16 Posts: 204
Try
Bottom 11.8kg/sqm 22mm (~15mm core 80kg/cu.m)
topsides/deck 9.3kg/sqm 18mm (~12mm core 80kg/cu.m)
This is some generic data I had for a 30'x10'4" beam 4000kg boat
Obviously, it depends on how long your string is... and what is has to do...
brett
Old 07-29-2002, 10:14 PM
Thanks Brett.
I assume the numbers you've given are for normal glass encapsulated foam - nothing too fancy.
They'll give me a good start, thanks again
Will
www.imaginocean.net
Old 07-29-2002, 11:18 PM
BrettM's Avatar
Rep: 16 Posts: 204
pretty much and E-glass foam laminate. Nothing too fancy.
Brett
Old 07-30-2002, 04:01 PM
Polarity Polarity is offline
Rep: 148 Posts: 480
Hi Will
I asssume you saw this...
http://boatdesign.net/articles/foam-core/index.htm
Old 07-30-2002, 07:24 PM
Yes thanks - I did see that. There is a fair bit of general info around on this type of construction, I was after more specific examples of just how thick and heavy the laminates should be for a particular sized boat.
Will
www.imaginocean.net
Old 07-30-2002, 08:20 PM
Jeff's Avatar
Jeff Jeff is online now
Moderator
Rep: 921 Posts: 1,371
You might also want to email Trevor Gundberg directly - Trevor.Gundberg@diabgroup.com - and see what example and quick calculations he can supply you with. I've found Trevor to be a great person to deal with.
Maybe we will also get him to put together a follow-up article for us this fall with more specific examples of prelim calculations and a few more detailed cross reference charts.
Old 07-30-2002, 09:26 PM
That sounds fantastic Jeff.
I'm always a little hesitant about approaching people directly about this sort of stuff - my knowledge of the subject is limited (to say the least!) and I hate appearing to be a complete goose - probably as much as they dislike being pestered by them!
But I'll drop him a note - and just say you sent me!!
Will
www.imaginocean.net
Old 07-31-2002, 11:24 PM
Jeff,
I contacted Trevor as you suggested. He was straight back to me and very helpful - thanks for the tip
Will
www.imaginocean.net
Old 09-09-2002, 05:44 PM
Evolution Yacht Evolution Yacht is offline
Rep: 10 Posts: 9
Sorry I am so late to this thread, but Dave Gerr's book boat strength has a lot of info on how to calculate prelim scantlings and weight calcs.
SG
Old 07-27-2004, 02:58 PM
JEM JEM is offline
Rep: 38 Posts: 291
I've heard from 2 designers the Dave Gerr's book has some short comings. What are they? Is it true? I don't have enough knowledge to express an opinion about it.
Old 07-27-2004, 05:22 PM
sorenfdk sorenfdk is offline
Yacht Designer
Rep: 389 Posts: 507
I think Dave Gerr's book is quite good, but not if you're into building very light.
Old 07-27-2004, 07:46 PM
mistral mistral is offline
Rep: 22 Posts: 154
come on Soren ,don't be shy , give us some good suggestions about related books on this topic, we'll greatly appreciate them
mistral
Old 07-27-2004, 07:54 PM
Yacht Designer
Rep: 389 Posts: 507
If I knew about any books about building lightweight boats, I would be happy to tell you about them, but unfortunately I don't...
If anybody does, please don't hesitate to tell us about them!
Old 07-27-2004, 09:52 PM
TheFisher TheFisher is offline
Registered
Rep: 60 Posts: 83
Personally, I'd accept a modest weight penalty for the benefits of additional strength.
The sea is an unforgiving mistress
Structural Foam mistysea Materials 6 05-10-2010 09:58 AM
PVC foam core thickness? Danielsan Fiberglass and Composite Boat Building 37 02-10-2005 01:45 PM
Newbie wants feedback about a foam roof... jimcorliss Materials 1 03-10-2004 06:23 PM
