Old 11-02-2007, 03:15 AM
Guillermo's Avatar
Ingeniero Naval
Rep: 2069 Posts: 3,574
Let's compare it with a well known product as Dyvinicell H130:
(http://www.diabgroup.com/europe/lite...df/H_DS_EU.pdf)
Nominal density: 130 kg/m3
Compressive strength: 3,0 MPa
Compressive modulus: 170 MPa
Tensile strength: 4,8 MPa
Tensile modulus: 175 MPa
Shear strength: 2,2 MPa
Shear Modulus: 50 MPa
Shear Strain: 40%
(1 Pascal = 1 Newton/sqm)
Old 11-02-2007, 06:09 AM
kengrome kengrome is offline
Rep: 287 Posts: 719
All I know how to compare here is the density and compressive strength, and although the divinycell is a little bit heavier it is also more than 4 times stronger in compression.
Kenneth Grome
Old 11-02-2007, 08:31 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1117 Posts: 1,648
Ken,
Yes, 3.0 MPa equals 3000 kN / m2, which pretty much rules Foamglas out of consideration. You wouldn't believe how difficult it is to find the compressive strength of Meranti ply though. I wanted it for comparison. According to the Forest Products Lab. in Wisconsin, ordinary sheathing plywood ranges between 20.7 to 34.5 MPa.
Old 11-02-2007, 02:11 PM
Man Overboard Man Overboard is offline
Tom Fugate
Rep: 129 Posts: 246
Meranti (Hydrotech) Compression Parallel to Grain - 52.9 N/mm2
Tom
Old 11-03-2007, 04:03 AM
Pericles's Avatar
Tom,
Thanks for that figure, which means if I have got the wording correct, the compressive strength may be expressed as 52.9 MPa. No wonder epoxy/Meranti ply composite craft are so tough!
Perry
composite construction - NA required nelly Boat Design 5 04-02-2007 12:05 PM
One off composite construction rapscallion Fiberglass and Composite Boat Building 12 03-09-2007 10:40 PM
Composite Construction Software Hypercat Fiberglass and Composite Boat Building 3 03-22-2005 02:05 AM
Is this progress in composite construction? Mark Peiffer Fiberglass and Composite Boat Building 16 01-13-2005 11:35 AM
Composite foam board sandwich technique scottperkinsusa Boat Design 11 09-18-2004 08:30 PM
