| flotation I am new to both this site and boat building. I am an avid diver and I want to build my own customized plywood boat specifically for diving and possibly overnight stays on the water. My first question si what type of hull would you reccomend: I am thinking a barge typr. Second would it help the flotaion if I stuffed styrofaom in all the available spaces that I can ? |
| It could help a bit if you tell are you using this boat at a local quarry or Puget sound and how many divers on board? |
| Sorry,Fresh water lakes here in Arkansas. Anywhere from 3 to 6 divers and equipment |
| Consider a catamaran platform for level stability. |
| It's about the same size I'm overhauling right now. I'll take and send you some pictures and sketches after a couple of days (a bit busy right now) |
| At the end of these construction pictures the Cat is fitted out as a dive boat. might give you some ideas.http://www.glen-l.com/picboards/picboard16/pic808a.html |
| Under Deck Foam Flotation? | CapeCodAngler | Wooden Boat Building and Restoration | 17 | 03-12-2009 11:21 AM |
| calculate pressure and flotation | rasorinc | Boat Design | 7 | 12-06-2008 08:44 PM |
| flotation | daedong | Boat Design | 10 | 08-02-2006 04:52 AM |
| Flotation Tube | nightz13 | Boat Design | 1 | 09-14-2004 10:10 AM |
| Flotation Tubes | nightz13 | Materials | 1 | 09-07-2004 04:55 AM |
