| Floating Deck Good afternoon gentlemen. I am planning to build a floating deck on a river, approximate size of 6m by 12m. The idee is,is to convert this in a floating bar on the river. It will be ancored from the river bank. It must be able to handle plus/minus 15 to 20 people plus the bar equipment. I was thinking of using this 210L plastic drums as the floatation device with a wood floor. What do you guys think off the idee and any suggestions would be helpfull. How much drums would be needed regards Henk Steyn |
The idea is great!! A real toerist trap! For the amount of drums, you need to figure out what the weight of the whole structure is going to be! a 210L drum, fully submerged, will carry 210 kg - own weight! When you figured that one out you will have to make a plan on how to place the drums. Maybe some extra under the bar, as this is a heavy object! Check stability!! When you're finished, invite me, we'll have a beer! |
Thanks for the advice , I will certainly invite you for a beer ![]() |
| Deck To Hull Joint | VIKING | Boatbuilding | 16 | 10-06-2008 08:57 PM |
| deck construction | Busted Knuckle | Materials | 12 | 06-26-2006 03:46 PM |
| New deck for a 1958 14' Thompson Runabout. | Sultana | Wooden Boat Building and Restoration | 3 | 05-01-2005 10:25 PM |
| Replacing a deck | Guest | Wooden Boat Building and Restoration | 3 | 11-07-2003 04:08 PM |
| Want to replace old Mako 19 deck with a "Flats boat deck" - am I crazy or what ! | dan | Boatbuilding | 4 | 09-24-2002 04:48 PM |
