| Flexible "fiberglass" wanted Does anyone know sources for flexible materials that can be used to for example to smooth rudder/trim-tab transitions.
__________________ May the wind blow briskly in your sails! |
| Not sure I fully understand what you mean! If you post a pic or a diagram I'm sure there's a material that would suit your application Alan |
| More accurate description. I am looking for a material with flexibility somewhat closer to vinyl but with fiber glass greater dimentional stability. Typical fiberglass will flex some but break abrubtly at a certain stress point, it also has a very high memory (springiness). Its does not stretch nearly as much as for examply vinyls so it is easier to make a fairly thin layer self supporting over short spans. One use would be to build a one-piece outer skin for a skeg and rudder so that a good foils shape could be maintained at all times. I hope this clarifyes things a bit. Thanks for responding.
| What about fibre reinforced rubber, similar to that in high pressure hoses. I'm still not sure what you are trying to do, why would you want to skin a rudder? Do you wish to adjust the foil shape, what type of boat is this on? |
| Epoxy can and has been formulated to have this quality. Most penetrating epoxies do. Call up an epoxy manufacture an talk it over with their chemist. |
| power boat molds wanted | bill johnson | Boat Molds | 2 | 12-01-2010 12:39 AM |
| engineering placement wanted | josch | Services & Employment | 0 | 03-30-2005 10:48 AM |
| Photos of Cruise Ships, Yachts, Tankers etc wanted! | Yachting | Marketplace | 1 | 10-28-2004 05:48 PM |
| Help Wanted: Westlawn Alumni to Celebrate 75th Anniversary! | dgerr | Education | 0 | 10-19-2004 12:10 PM |
| Experienced Naval Architecture Wanted | Services & Employment | 2 | 03-16-2004 07:04 AM | |
