Old 01-30-2010, 10:59 PM
WesS WesS is offline
Rep: 10 Posts: 33
Flat camo Paint over epoxy
I am building a wooden duck hunting boat and wondering what the best paint is to use over the West Systems epoxy. I want it to be OD green. Don't want to spend a fortune, but want it to last. I am rough on things in the water though. Thanks.
Old 01-30-2010, 11:07 PM
Rep: 1397 Posts: 7,216
You can use any paint over it. Make sure you take the amine wax off first. A scrubby pad with dish washing detergent works best.
Old 01-31-2010, 03:43 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
2k PU paints can tolerate most abuse, but they are also the most expensive choice.. but like Gonzo said, you can pretty much use anything..
Old 01-31-2010, 11:30 AM
Camo paint is flat and multicolor. Patches don't show.
Old 01-31-2010, 05:52 PM
Rep: 10 Posts: 33
Do I need to start with a pu primer, latex based. Then move onto pu flat od green or use any latex flat? Also- who would carry a OD green flat pu paint?
Old 01-31-2010, 06:04 PM
Home Depot has flat paint. Exterior acrylic latex works fine
Old 01-31-2010, 07:03 PM
Rep: 10 Posts: 33
acrylic latex primer as well
Old 01-31-2010, 09:16 PM
Yes. They sell four colors of flat camo paint in spray cans too.
Old 02-03-2010, 10:02 AM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,731
If you are using dark colors...you may have a problem with the epoxy softening in the hot sun. Store it out of the sun if it has lots of OD green, black or dark Brown...the desert colors are much kinder tho. If you are painting it to blend in with tan reeds and such you should be oK.
Flat bottom/vertical sides/flat deck/ flat everything Ron Cook Sailboats 74 08-12-2009 09:51 AM
Paint over Epoxy Manie B Boatbuilding 4 09-11-2008 07:10 PM
Epoxy, Paint, or what??? Mr V Wooden Boat Building and Restoration 13 01-08-2005 07:45 PM
Paint question over epoxy zember311 Boatbuilding 5 11-26-2004 03:22 PM
flat paint daniel k Materials 0 06-27-2004 11:05 PM
