Old 07-05-2010, 04:50 PM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
1 x4 or 1x6 T & G tight butt not a V butt, cheap stuff 40 to 50 cents a LF. stain and a good wood preservative. your good for 6 to 8 years or more
Old 07-05-2010, 05:29 PM
Boston's Avatar
Boston Boston is offline
Rep: 1457 Posts: 3,355
aluminum diamond plate seems like your best bet to me
cheers
B
I am skeptical of the deniers diatribe
Old 08-04-2010, 06:58 AM
Anytec1210 Anytec1210 is offline
Rep: 69 Posts: 44
Hovercraft Trailer
Run a Ivanoff IH-6 during winter but the trailer configuration will probably work for most crafts and would like to have some good pictures to show but Iīm affraid I then have to remove the summer cover and unload. You can however perhaps get the basics.
First you build a flat bed at the size of your hover. Use prefebly form- plywood (donīt know what you call it but is the same stuff you build concrete molds of. Not the sheep stuff. The same as the pros use when they build bridges and stuff)
Second you build a frame about 10 to 15 inches high frame around all sides but the one in the back. If you have a smaller craft you can perhaps make it with straight ones but I suggest that you tilt them about 45 deg outwards since that will minimize the risk of tearing your skirt while loading. However the hight of the side frame shal be at least 2/3 of your maximum skirt height.
In the back you build a larger loadingramp. Same priciples as your sides but longer. How long you haev to figure out on your own and depends on how high you can ride your hover. The IH-6 rides at max of about 30cm (1 ft) fully inflated and the floor on the trailer are at about the same hight over ground so the loading ramp on the trailer is about 2 ft long. I think it could be longer since it sometimes can get stuck while loading/unloading.
Last you need two side covers in the back so the air donīt leak out at the same moment as you try to get up on the trailer. Place two triangular shaped pieces on either side of your loading ramp and attach them with hinges to the end of the sidecovers.
Place some rubber over all transitions to minimize air leakage and remember to also se to that you have a rubber transition between the side covers of the loading ramp and the ramp only attached to one side.
If you are serious enough let me know and I can perhaps se if I can make some pictures of how it looks but here you have at least something for both a large craft (like to one described) and a smaller one.
PS. Iīm writng this in a car with three boored kids that are all over the place so apologies for any poor writing.
Old 08-04-2010, 02:05 PM
kroberts's Avatar
kroberts kroberts is offline
Rep: 178 Posts: 282
Are you Magnus? If so I think we met once at WHC2002. Anyway, nice machine.
The mechanics of the trailer are something I'm familiar with, it's the deck material I'm worried about. I've put it off awhile to think about it, I'm cleaning up the trailer and painting it right now.
Thanks.
-- Ken
No builds yet. Learning first!
Old 08-04-2010, 04:04 PM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
Anytech .......hit the kids harder...
Old 08-05-2010, 01:36 AM
Rep: 69 Posts: 44
Donīt over analyse. Canīt tell you the name but there must be a wooden material thatīs affordable to use.
Here is it usually (what I call) form plywood but just go out and look whatīs put on a simple flatbed trailer where you are.
Old 08-05-2010, 12:53 PM
kroberts's Avatar
Rep: 178 Posts: 282
I've been doing that. I've re-decked this trailer 3 times now using simple wooden materials and I'm looking for something different. No matter how you seal it, sooner or later a nick or gouge gets in there and the glue comes apart, and then the whole deck disintegrates.
Most normal flat-bed trailers around here for non-hovercraft applications use treated lumber as the deck, and then have gaps for expansion. Nobody uses plywood except the hovercraft people. Since I'm not trying to drive a skid loader on it I figured something lighter, but I would like to get something that's not going to rot on me, something that will last more than a couple years.
-- Ken
Old 08-06-2010, 05:16 AM
Rep: 69 Posts: 44
Maybe we are not talking about the same stuff then. Really sorry I canīt help but the stuff I use is more like simmilar to mdf rather than plywood so there is no glueed sheets that can split.
When they make reusable molds for concrete, this is what they use and itīs very water resitant, unexpesive and durable.
Iīll se if I can come up with a name that helps your furter.
Old 08-07-2010, 01:19 AM
kroberts's Avatar
Rep: 178 Posts: 282
I've been looking around a bit for wood concrete forms. There are dozens of different types, so I'm not exactly sure what you're talking about if it's not actual plywood. I'll hit a few home improvement stores this weekend and see if they have something further. There's also a concrete work place, where contractors go to get concrete sewer line and such.
Thanks.
-- Ken
  #25
Old 08-07-2010, 01:44 AM
Boston's Avatar
that IH-6 is hands down my fav of the hovers I've seen so far
B
  #26
Old 08-07-2010, 07:45 PM
kroberts's Avatar
Rep: 178 Posts: 282
It's a genuine work machine. Unfortunately barred from commercial service in the USA by a silly little law that hurts us more than helps.
-- Ken
  #27
Old 08-19-2010, 02:26 PM
Rep: 69 Posts: 44
Itīs a great machine Boston. Comfortable, reliable and safe and not to difficult to maintain. Check out. There are some movies on youtube. Look for Ivanoff IH-6 or Ivanoff BBV-6 (older modell but very similar)
  #28
Old 08-19-2010, 04:59 PM
apex1
The material Anytec referred to is a laminated board, the outer sides are commonly acrylic PUR resin or Polymaleimide structures applied by high pressure, therefore these boards are known as "HPL" (high pressure laminate) board.
Betoplan is another material used to pour concrete and to make truckbed liners.
Hope that helps.
Richard
Ähh, yes, the Ivanoff is a cool Hovercraft, no doubt.
  #29
Old 08-20-2010, 01:36 AM
Rep: 69 Posts: 44
I think Richard is on to the material you should be looking for. As said I donīt know what its called but it works.
kroberts what machine do you have?
  #30
Old 08-22-2010, 02:39 PM
kroberts's Avatar
Rep: 178 Posts: 282
I have a Universal Hovercraft UH-18sp. I'll look into this stuff.
Thanks.
-- Ken
Flat bottom/vertical sides/flat deck/ flat everything Ron Cook Sailboats 74 08-12-2009 08:51 AM
engine bed and stringers fishweed Fiberglass and Composite Boat Building 7 04-11-2008 07:54 AM
Engine bed CarlosSan Inboards 1 01-18-2008 07:26 AM
Columbia39 flat deck for sale MarioCoccon Sailboats 3 05-10-2006 11:25 PM
polyurathane bed liner overshoot Wooden Boat Building and Restoration 1 02-28-2006 11:29 AM
