Old 02-04-2010, 01:52 AM
Saylaman Saylaman is offline
Rep: 43 Posts: 35
I pulled out my old book on ferro cement boat building. 'How To Build a Ferro Cement Boat' by Sampson and Wellens, two well known personalities in the ferro scene. I scanned in the section where they answer the question regarding how to fix a hole. It is attached. Pretty much what we've recommended, beat out the old mortar, fix the steel, re plaster and seal with epoxy.
Old 01-21-2011, 10:55 AM
Wake31 Wake31 is offline
Rep: 10 Posts: 12
I am about to pull my 45' ferro up on the weighs to fix a L shaped tear in the port side. What do you recommend I use as my mix? Portland V or portland III cement? I have the weighs for a week, then the boat has to be back in the water. I was told by the boat works that it was a benefit to cover the entire patch with epoxy and cloth. Do you recommend this? Will this ensure a water tight seal? How long after I repair her should I keep a damp towel on the patch? I will only be able to towel the inside as it will be in the water. What epoxy should I use as a bond between the new and old cement?
Old 01-21-2011, 02:45 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Mad Scientist
Rep: 1786 Posts: 2,985
Please open the attachment in post #16. It will answer your questions.
Use a good, strong quick-setting mix. West system 3 or equal quality epoxy should be fine. Dampen it for 2 days should be adequate before letting it dry for epoxy.
Hoyt
Lighting is very selective and will not strike crap. Wynand N
http://www.genocidewatch.org/southafrica.html http://www.saabc.net/
Help Identifying military 36 foot inverted V hull Argonaut Powerboats 19 06-07-2011 09:43 AM
Selling 30 Foot Cat hull - Cheap Rory in Florida Multihulls 10 12-19-2008 09:38 AM
6 foot by 8 foot homemade barrel raft StabbyJoe89 Boatbuilding 1 08-01-2008 10:47 PM
Hull thickness for 16 foot skiff willfishforbeer Fiberglass and Composite Boat Building 10 03-18-2007 09:46 AM
help with design of 26 foot cat hull rlewis Boat Design 11 10-11-2004 02:57 PM
