Old 10-09-2004, 07:42 AM
raymond raymond is offline
Rep: 10 Posts: 24
Fixing interior wall panel
To my knowledge, there are two types of method to install veneer wall panel inside the yatch.
I can use PU adhesive to glue them on partition. However, it is diffcult to replace it if there is any damage to the panel surface. PU adhesive is too hard to remove once they dry.
The other is to do it in assemble way. Of course, it is much easy to change all defect items. But, it creates noise as well when the yatch sail.
I don't know what should be the right way. Is there anyone can give me some advice?
Generating stich and glue panel templates small cat Wooden Boat Building and Restoration 9 07-14-2005 12:01 PM
Invitation to join SNAME technical panel wlasher Sailboats 9 07-13-2005 12:53 PM
Easier way for balsa core deck replacement? pago cruiser Boatbuilding 4 06-01-2005 07:20 PM
Electronic Panel...need to make... Joito_911 Electrical Systems 2 03-10-2004 02:36 AM
Calculation of the hull panel from Larsson Gades Boat Design 1 09-18-2002 05:42 PM
