Old 06-22-2008, 09:42 PM
waxer waxer is offline
Rep: 10 Posts: 6
Fir Douglas-Fir
Is the Fir used in boat building, Douglas-Fir (which I believe is not a true Fir)?
Also, any comparison of Fir to Hem-Fir? Would it be an alternative?
Thanks.
Old 06-22-2008, 10:39 PM
alan white's Avatar
alan white alan white is online now
Rep: 1168 Posts: 3,269
Hem-fir is a marketing name. If it's hem-fir it might be hemlock or fir.
Doug fir is a fir as far as I'm concerned--- that is, it is okay for boat work.
It should straight grained and have narrow (1/8" wide or smaller) growth rings.
The face of the boards should be mostly quarter-sawn. In other words, the wood is most valuable and shrinks/expands least when cut from outside to inside of the tree. Weight should be about 34 lbs cu. ft.
Alan
Kiln Dried vs Air dried Douglas Fir Thomas Wick Boat Design 6 02-11-2008 08:34 PM
marine grade fir flatscat Materials 2 08-12-2007 10:27 PM
Douglas Fir drs3317 Wooden Boat Building and Restoration 17 06-10-2006 08:50 PM
Plywood or Douglas Fir supports? drs3317 Wooden Boat Building and Restoration 10 12-14-2005 09:20 PM
Douglas Fir Mast. CPES - use in restore/refinish? Robert Miller Wooden Boat Building and Restoration 2 09-13-2005 02:38 AM
