Old 07-19-2007, 12:09 PM
Agewon Agewon is offline
Rep: 10 Posts: 23
Finish Coat
I am new to this forum and have already found numerous tips that will hep me with my project. I am making a cooler liner for a teak box and was unsure of the finishing steps. I have made a mold from plywood covered with laminate, waxed the mold with three cured coats of Meguires, and am at a standstill. My question; if i spray laminating gelcoat to the mold (After applying PVA) will my fiberglass/ epoxy layup bond to the gelcoat? I have read many bulletins that say no, and a few that give very presice directions to make it bond. I am using West Systems 105 resin.
Or am i wasting my time? Should i just layup the glass, pull the part from the mold, and add several 6 mil barrier coats to the finish side, then paint?
Also, i plan to use 2 part floatation foam for the insulation. Should 2" thickness be sufficient?
Any advice will be greatly appreciated.
Old 07-19-2007, 05:43 PM
Rep: 10 Posts: 23
To answer my own question; I have spoken with West Systems and was told that the proper way was to use waxed gel coat and allow it to cure. When fully cured, de-wax and prep surface with 60 grit. Then appy layup as usual. It seems that if the gel coat is not fully cured, the "tack" will create a barrier and not allow the epoxy to set.
West Systems was very helpful and i would recommend their products. I hope I may have also helped anyone with the same issues.
What should I finish a new plug in? Thin water Fiberglass and Composite Boat Building 3 07-06-2007 07:26 PM
finish the finish?? richard567 Fiberglass and Composite Boat Building 0 05-31-2007 11:38 PM
Finish varnish coat DavidJ Wooden Boat Building and Restoration 0 06-20-2004 09:38 PM
Boat Finish Materials 4 03-30-2003 09:24 PM
GRP finish andy_s Fiberglass and Composite Boat Building 2 01-31-2003 02:41 AM
