Old 05-18-2009, 08:43 AM
film842 film842 is offline
Rep: 10 Posts: 4
fiberglassing over MDO
Is there any reason why one could not glass over MDO plywood?
As I understand it, the MDO surface is compressed wood fiber, so I can't see that there would be any issues using proper prep methods, but would like other opinions.
Old 05-18-2009, 06:34 PM
Cobra1 Cobra1 is offline
Rep: 9 Posts: 82
What are you going to do with it, or what are you trying to achive??
Old 05-18-2009, 07:21 PM
apex1
There is definitely NO reason why one should, or could not cover a MDO with a glass/resin compound!!!!!!
The question is : what is the goal? does it make any sense? Do you have to much money?
At least one of the questions above should be answered to get a better response on your query.
Regards
Richard
Old 05-18-2009, 08:02 PM
Rep: 3125 Posts: 9,399
MDO has resin soaked paper face(s) on one or both side over a WBP adhesive, minimum ply count sheet. It's questionable if you'd want to bond to this paper, though my tests have shown it's very well stuck.
For best results, you should abate the paper off, down to the surface veneer, then bond to this.
Old 05-18-2009, 08:44 PM
Rep: 418 Posts: 777
I've found mdo plywood to be one the secret good deals around here in Puget Sound country. Pretty decent quality, holds up to the weather nicely, reasonably priced. The paper is almost impervious to ill treatment. It's a delight to work with. I'd risk fiberglass on something small and see what happened.
Old 05-18-2009, 08:59 PM
Rep: 10 Posts: 4
I"m restoring a 34 year old dory style powerboat (23') whose hull was originally sheathed with two layers of 5/8" MDO plywood. I want to epoxy and glass the hull up to the waterline for abrasion resistance and some stiffening.
I will not be glassing the interior.
Regards
Richard
Old 05-18-2009, 09:44 PM
apex1
I am shure we have to make clear what YOU understand to be MDO
Old 05-18-2009, 11:04 PM
A lot of manufactures used MDO back then. It use to be pretty good stuff, but quality has declined dramatically in the last 15 years.
You will gain no additional strength from a light weight sheathing, but will increase abrasion resistance substantially. Go for it.
Old 05-19-2009, 09:03 AM
Rep: 10 Posts: 4
I understand MDO to be exactly what the American Plywood Association describes it to be.
Old 05-19-2009, 10:19 AM
apex1
Sorry, my mistake, I was mixing MDF and MDO in my old brain.
Old 05-19-2009, 02:36 PM
The APA's rating system is voluntary in the USA and by no means any guide, as manufactures pretty much do what they want. The only things that seem to actually follow the APA recommendations are WPB adhesives and species selection. Defects permitted, repairs, voids, general construction, etc. all seem subject to whim by all but a few mills.
Your approach seems fine Film842, though I would recommend coating the bilge areas as well, to protect against sweet water pooling there and causing trouble. Better yet would be sheathing the bilge areas lightly for abrasion reasons only. Don't try to wrap over or around stuff, just flat places where a tool or bit of gear can roll around or bang into something and dig up some wood.
When fiberglassing decks... mosquitolaGOON Fiberglass and Composite Boat Building 2 04-23-2008 05:04 AM
Fiberglassing MDO drs3317 Fiberglass and Composite Boat Building 1 06-09-2005 01:43 PM
Mdo drs3317 Materials 2 12-01-2004 09:40 AM
Fiberglassing Bqman Fiberglass and Composite Boat Building 3 11-02-2004 02:59 AM
MDO Plywood gngraham Boatbuilding 6 05-06-2004 08:26 PM
