| Fiberglass fuel tanks Many have had problems with ethanol and fiberglass fuel tanks, including me. I replaced mine before any real degradation took place. My question relates to composite material fuel tanks buried at filing stations. Many leaking metal tanks have been replaced with fiberglass tanks over the years. Has anyone heard of problems with these or might it be a disaster happening in the dark? I'm not trying to start a chicken little issue, just looking for information. If it is a problem, I don't know whether to laugh or cry.
| Replaced them with what, plastic? -Tom |
| I thought the 'glass portion of the new in ground tank upgrades, was the "containment" walls that are now placed around tanks. |
| I've researched this issue a bit more. Large fiberglass fuel storage tanks and piping has been approved for use with ethanol for quite a while. The resins used must be compatible but apparently there are resins and fabrics or fibers that will take this service. If the materials and methods are compatible with home use, I'd like to know what they are since that could open up the possibility of home built fiberglass tanks again. The same source says that distributors do have problems with ethanol and have sometimes only added it to the delivery trucks to reduce the time it is in the fuel before use. That doesn't sound very good for the consumer. The problem is greater for greater percentages of ethanol. Still a pathetic boondoggle foisted on us by greedy politicians, lobbies and big agriculture.
| I believe most of the problems with ethanol and FRP tanks came from early boats using polyester laminating resin to build the tanks. A boat fuel tank manufactured with vinylester resin, and most are, should be fine with ethanol. Many of the tanks under gas stations are vinylester based frp. |
| Or epoxy . . . it is just usually more expensive. Your wife has the right idea :-) |
| yes, polyester is the problem as I recall |
| Fuel Tanks | messman | Boat Design | 3 | 08-07-2010 04:35 PM |
| Ethanol + fiberglass fuel tanks | Challenger1 | Jet Drives | 5 | 03-28-2010 09:34 PM |
| Fuel Tanks. | Buckie | Boat Design | 15 | 10-01-2009 11:24 AM |
| Fuel Tanks | wikark | Marketplace | 0 | 12-03-2007 09:28 PM |
| Fiberglass Fuel Tanks | boatlover24 | Fiberglass and Composite Boat Building | 3 | 06-21-2005 02:43 PM |
