| Fiberglass 101 Hello, First let me say that I am totaly impressed with this site and the amount of expertise available. That said, I have in the past couple months purchased 4 fiberglass runabouts in need of repair. I have the woodworking and mechanical skills needed, but am lacking in experience working with fiberglass. I have at this moment 1296.5 questions regarding fiberglass types, uses, and bonding materials. Before I wear out my welcome with a lot of dumb questions, could any of you recommend some educational books or websites that will help me understand at least the basics. Your time and thoughts are (and will be ) very much appreciated. Mark |
| Fiberglass Boat Design and Construction by Robert J. Scott Marine Composites by Eric Green Composite Materials in Maritime Structures by Shenoi and Wellicome Composites-Design Manual by J.A. Quinn The Handbook of Sandwich Construction by D.Zenkert These books are the ones most referenced in my library. |
| Thank you, I will check them out. |
| Penn yan swift fiberglass? I have an old 50's era Penn Yan Swift that I would love to get in the water. The canvas layer on the hull is not in the best shape (still tight on the hull, but probably not watertight. I would love to fiberglass the bottom and have someone to help me with that, but my question is should the canvas stay or should I fiberglass the bare wood? Would fiberglassing the bottom even work on a boat this old? Any few words of wisdom would be greatly appreciated. |
| Penn Yan restoration Thought I had the only swift here in the Pac NW . Anyway, I explored several options including recanvasing (materials available locally) or fiberglassing. I went with West Systems after removing canvas and sanding hull lightly. Replaced and beefed up transom. Came out beautifully and I run a speeditwin or Mark 25. You could probably use expertise and materials from Fiberlay, too...they are great folks to work with.Cheers Richard |
| regarding your Swift, -back here in the Eastern US (Penn Yan, NY area). Your boat is worth considerable money. I would suggest to re-canvas. fiberglass will ruin the value to the point of almost firewood. From a technical standpoint though, dont glass over the canvas. |
| Thanks.....we do have some great expertise in recanvasing here in Seattle. I sure love the boat! |
| fiberglast.com has some great dvds on all kinds of glassing and sell plenty of materal |
| fiberglast Just sent away for the catalog...thanks for the tip |
| Fiberglass boatbuilding by GlenL. |
| Fiberglass fire damage to a fiberglass boat | Eagle Boats | Fiberglass and Composite Boat Building | 26 | 11-14-2011 12:17 PM |
| fiberglass help | MF11283 | Fiberglass and Composite Boat Building | 9 | 09-25-2005 02:53 PM |
| Fiberglass Molds????? | OCEANS_77 | Fiberglass and Composite Boat Building | 2 | 07-16-2005 11:52 AM |
| fiberglass strip | ricardoribeiro | Fiberglass and Composite Boat Building | 0 | 11-20-2004 04:50 PM |
| I Need Some Help On Fiberglass Work | Rob G | Fiberglass and Composite Boat Building | 1 | 03-17-2004 11:02 AM |
