Old 09-17-2004, 03:44 AM
mistral mistral is offline
Rep: 22 Posts: 154
fiber content in GRP laminates ???
the question is quite easy:
-Wich is the tipical glass content in a classic glass and polyester/vinylester resin laminate (hand lay-up)???????
In literature i found values of 28% using Chopped Strand Mat and 38% using Wave Roven or biaxial fabric; so 28% of total weigt is made by reinforcments fibers usind CSM.
some other following questions, maybe not so easy........
-are these vaules reliable???
-wich is the difference between a very carefully operated hand-layup and a "standard" one??? I mean: how much more resin can I squeeze out from laminate????
and the ultimate question:
-How much does vacuum bagging improve this ratios??????
thanks
Mistral
Old 09-17-2004, 04:31 AM
Rep: 66 Posts: 640
I had a similar question. here's the thread with some answers:
Fibre content GRP
Dutch Peter
Old 09-17-2004, 06:04 AM
Rep: 22 Posts: 154
ok, thanks Peter, that's what i was looking for; now let's see if some shipyard-guy will answer our questions with direct knowledge on the subject ; i need reliable numbers to calculate as exactly as i can a hull's weight. Few percentage points of difference mean a great amount of resin (and weight....)
fair wind
mistral
Old 09-17-2004, 06:21 AM
Rep: 66 Posts: 640
How critical is this weight? You could have the yard make a lay-up and do a burn test to determine the glass/resin ratio.
Dutch Peter
Old 09-17-2004, 10:01 AM
Rep: 22 Posts: 154
as a matter of fact i think that i'll build up some test-panel, 1 square meter sandwich, to have reliable results; the weight is not so much critical (the boat is not a racer), but it takes a slight difference in fiber/resin ratio to have 30kg weight difference in a 9m hull!!!!! Altough she's not a racer i prefer to employ weight in more useful way than adding a bunch of brittle unesuful resin to the hull
Mistral
Old 09-23-2004, 12:51 AM
Not A Guest Not A Guest is offline
Registered
Rep: 10 Posts: 55
It may be easier to use a better weave than to worry about the best ratio.
Unidirectional cloth will be about 60% fiber (weight).
Satin weave about 50%.
Plain weave about 40%
Resin infusion and resin content sorenfdk Fiberglass and Composite Boat Building 23 05-17-2011 08:02 AM
Are These Laminates Too Heavy? Advice On Pvc Honeycomb Cores. VIKING Fiberglass and Composite Boat Building 21 11-04-2005 09:26 AM
Birsmouth mast & carbon fiber tape Robert Miller Wooden Boat Building and Restoration 1 05-23-2005 06:02 PM
Fibre content GRP Dutch Peter Fiberglass and Composite Boat Building 5 08-27-2004 08:54 AM
Carbon Fiber Mast/pushpole Kits JR-Shine Marketplace 0 07-13-2004 11:07 AM
