Old 02-04-2012, 02:15 AM
davidcarey davidcarey is offline
Rep: 10 Posts: 11
evo-stik serious stuff
Is evo-stik "serious stuff" a viable alternative to epoxy , i was thinking in terms of stitch and glue , or strip planking small boats . Has anyone actually used this ?
Old 02-04-2012, 11:30 PM
Rep: 1493 Posts: 7,447
If you are going to fiberglass over, it is possible. However, I don't see any advantage on using mis-matched adhesives.
Old 02-05-2012, 08:40 AM
Rep: 10 Posts: 11
advantages . comes in a tube - easy to apply
fast setting , so the website says
waterproof , heat proof ,
price in uk is about 8 pounds for 290ml , how does this compare with epoxy ? epoxy is not a particularly nice product to use .
http://www.bostik.co.uk/diy/product/...rious-Stuff/22
Old 02-05-2012, 10:51 AM
Rep: 3125 Posts: 9,399
Not familiar with this stuff, but what level of waterproofness is it? Can it pass the "type 1" test? Is it compatible with epoxy, so a sheathing will remain stuck? Sounds like is more costly and sets up too fast for reasonable assembly times. It seems to be a single part polyurethane, which will work, but again it's going to be more costly then epoxy in the same quantities, though possably easier to squirt out of a caulking gun. You can squirt epoxy out of a gun too, so . . .
PAR Plans
PARBlog
Old 02-05-2012, 03:26 PM
Nick.K Nick.K is offline
Rep: 60 Posts: 111
Register with Bostick, download the safety data sheet and find out what is in the tube. Very often these type of tubes contain an acrylic based adhesive similar to decorators caulk. If that is the case, definitely not an appropriate adhesive for boat use...in my opinion.
Nick.
AQWA Stuff CWTeebs Software 29 05-23-2012 09:31 AM
portholes and stuff gclay9999 Boatbuilding 11 11-16-2009 06:21 PM
Plywood - is this stuff ok? ako Materials 6 05-30-2007 02:27 PM
Just some stuff Andrey Education 3 06-19-2004 08:07 PM
Cool stuff!!!!!!!!!!!!! Josh Open Discussion: All Things Boats & Boating 4 09-10-2003 06:44 PM
