Old 02-16-2011, 02:43 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
OK, so you are saying that your health is not worth some 30-35 euros???
Make sure the epoxy is well cured before sanding. (this is true for all resins to be sanded).
Also you could invest in a "sanding table" wich basicly is a box with a mesh, grid or perforated sheet on top, and a vacuum cleaner attached. This will draw the dust away from you.
4.3L Vortec mercruiser cracked block - swap with automotive engine block? mmanning63 DIY Marinizing 75 08-22-2011 04:21 AM
Epoxy Encapsulation and Varnish MastMonkey Wooden Boat Building and Restoration 9 08-27-2010 10:32 AM
White gelcoat yellowing problem ? pescaloco Fiberglass and Composite Boat Building 6 11-09-2009 10:25 AM
chemical removal of yellowing white gel ? pescaloco Materials 32 09-11-2009 12:42 AM
varnish or epoxy 2geekie Wooden Boat Building and Restoration 17 04-09-2008 12:16 PM
