Old 12-07-2005, 04:44 PM
RichardM RichardM is offline
Rep: 10 Posts: 3
Epoxy vs Vinyl vs Polly
I am boat shopping and I'm fairly new to boating and I'm confused by the different types of resins and methods being employed. Everyone seems to agree vacuum bag wet-out and epoxy resin apears to be the superior method of hull construction. Lighter, stronger, more stiff, better bonding, lower water transmitence and overall most cost effective.
If it were simply a matter of economics, i.e. epoxy cost more than vinyl and vilyl more than polly I could understand why manufacturers choose different methods, but I am finding sport fish boats fabricated with epoxy construction competitively priced to their polly and vinyl counterparts.
Am I missing something? Why don't all builders use epoxy?
Old 12-07-2005, 08:00 PM
Rep: 1397 Posts: 7,215
Polyester resin costs about 1/4 of epoxy. It is also easier to use. It wets faster and the mix ratio is not as critical. For medium performance applications, where minimum weight is not necessary, epoxy is a waste. On the other hand, the cost of the hull is maybe 10% of the total boat. That means that using epoxy increases the total cost by 15-20%.
Old 12-07-2005, 11:50 PM
Deering Deering is offline
Rep: 14 Posts: 219
Epoxy is clearly superior in most respects. If I could buy the same boat, for the same price, in either epoxy or polyester, epoxy wins hands down, regardless of the usage. Different boats, different prices... now you need to consider other factors as well.
Did that help? No? Sorry... welcome to boating.
Old 12-08-2005, 12:41 AM
John ilett's Avatar
John ilett John ilett is offline
Rep: 23 Posts: 131
Poly or Viynelester boats can all use gelcoats to get the nice durable and glossy moulded finish whereas epoxy gelcoats do not really exist. For a moulded epoxy hull a poly gel can be applied with extra tie coats or needs to be painted which is not so durable.
Old 12-08-2005, 11:27 AM
Rep: 10 Posts: 3
Thanks John. I thought urethanes were taking the place of gelcoats o0n epoxy hulls.
Old 12-08-2005, 03:25 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
I think polyurethan paints can last as long as polyester gelcoat and look better without any waxing.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 12-08-2005, 07:17 PM
John ilett's Avatar
Rep: 23 Posts: 131
Gelcoats may need polishing in the longer term but are harder, thicker and more durable (abrasion durability) than paints. Your paints are generally thin and when scratched will cut through to your undercoat or primer to often show another colour. Sure paints look good when new but but may look pretty average 5 years down the track. I feel when restoring older boats the gelcoat finish should be kept and maintained as long as possible.
Old 12-09-2005, 08:51 AM
JR-Shine JR-Shine is offline
SHINE
Rep: 50 Posts: 282
I second this opinion - Gel coats may be harder, but they are also much more brittle - they crack. paint will not crack as easy.
Unless you need it to build something in a mold - I cant think of any other application where I would prefer it over paint.
Old 12-09-2005, 09:06 AM
John ilett's Avatar
Rep: 23 Posts: 131
The gel only cracks where a laminate is too flexible, usually solid laminate boats without sandwich construction.
Old 12-09-2005, 09:14 AM
SHINE
Rep: 50 Posts: 282
Please explain cracks in gelcoat around mounted hardware (hinges, bowrails, consoles, etc....)
Old 12-09-2005, 09:24 AM
John ilett's Avatar
Rep: 23 Posts: 131
These are points where the laminate is flexed I imagine.
Old 12-09-2005, 09:30 AM
SHINE
Rep: 50 Posts: 282
I disagree, the gelcoat can crack due to its being brittle alone - the laminate under it does not need to move.
You are right also, it the laminate moves - then the gelcoat will most likely crack.
Old 12-10-2005, 02:48 AM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
But, but, but, John, how can that be, all the old salts I've talked to insist that solid laminates are much stronger....
Yoke.
Old 12-10-2005, 03:36 AM
John ilett's Avatar
Rep: 23 Posts: 131
A solid laminate boat is more robust and fail safe like, but that does not stop them flexing. The laminate will flex (not fail) and the gel coat being brittle cracks.
Sandwich boats are typically much thicker/stiffer and do not flex.
Old 12-10-2005, 06:11 AM
Rep: 700 Posts: 3,208
"all the old salts I've talked to insist that solid laminates are much stronger..."
What has fooled the "old salts" is that at high load spots the solid laminate is usually stiffer than cored material with poor (quick) construction for the high load.
Cracks in gelcoat at stress points is a SURE sign of broken laminate and the need for a robust repair..
Most glass is strong enough , but getting it stiff enough to not come unglued over the years is always the hard design part.
Basically if its stiff enough to never flex , it may weigh a bit more , but will last almost forever.
The old glass boats , that were built to what would be insane scantlings today , dont flex and will live till sunk, or burned.
FAST FRED
Epoxy vs Polly & Vinyl RichardM Fiberglass and Composite Boat Building 2 12-12-2005 05:47 AM
Epoxy over Polyester Blue Heron Fiberglass and Composite Boat Building 6 12-09-2005 12:48 PM
Epoxy crystallization jfblouin Materials 4 09-15-2005 12:19 PM
Easier way for balsa core deck replacement? pago cruiser Boatbuilding 4 06-01-2005 07:20 PM
epoxy vs vinyl lprimina Fiberglass and Composite Boat Building 8 11-27-2004 07:09 PM
