| epoxy specifications Does sombody out there knows the density (g per ccm) of glas fiber reinforced epoxy of the kind one uses for building boat hulls. I'm just playing around with modelling boats (a 8 meter and a 5.5 meter center console fishing power boat) and would like to calculate the weight of the hull and deck etc. How thick are the outer and inner walls of a boat like described and are they constant from the keel up to the hand rail? Marco. |
This depends on the panel size you use, so where is your primairy structure located. From there you can calculate the skin thickness you need. |
| I am not an expert in boat building at all. I am also not really intended to build one of them. Just seriously curious about how the boats could be made. The boats, I thought, should be made out of two shells, which then will be clued together with either an expansion or floatation foam. So I thought the outer shell will be thicker then the inner one. What I do not know is whether this construction works and if it will become something stiff like a core sandwich construction. Quote:
May a little explanation, why I am interested in density figures. As one can see, the boats are built in a 3D application which allows me to calculate volumes and points of mass gravity center. If I could calculate the approximate weight of my hulls I can better define the water lines and the all over shape - since that is what I am really interested in as a designer. I am sorry, if some questions and thoughts sound a bit strange to a prof. But I appreciate all informations I can get. Marco. |
| mselle I'm working on the same solutions and the specs are wide and plenty of manufactures to chose from. I my self as a beginner have learned a great deal talking with pros and beginners alike on the forum. But there are times when the answers just don't come at the stroke of the keys. I have surfed a gazillion web sites looking for everything. So I've resorted to the shade tree on several occassions. Simply put most manufactures will send you small samples of materials, i.e. core, glass etc. I picked some popular systems that are proofed and true and started to weigh 1sq. ft. at a time from the core to the first glass lay-up etc. etc. Guys .. stop me if I'm waisting time or having too much fun .... I hav'nt completed yet and don't have the final answers carved in the tree yet but it makes good since.....Huh? ..... Well? donjames |
Keep asking!! Peter |
| Epoxy crystallization | jfblouin | Materials | 4 | 09-15-2005 12:19 PM |
| Easier way for balsa core deck replacement? | pago cruiser | Boatbuilding | 4 | 06-01-2005 07:20 PM |
| Epoxy......how much i need? | {NW}BKUSA | Wooden Boat Building and Restoration | 7 | 01-21-2005 06:14 AM |
| Paint question over epoxy | zember311 | Boatbuilding | 5 | 11-26-2004 03:22 PM |
| Gelcoat over Epoxy | wet-foot | Boat Design | 9 | 08-16-2004 07:58 PM |
