Old 05-02-2006, 09:01 PM
sbklf sbklf is offline
Rep: 10 Posts: 43
Epoxy resin and cloth selection questions
I am trying to decide on the brand of epoxy to use to repair my boat. I thought I would use Raka but have learned of some more options. I am concerned about blush between coats. The Epoxy-plus from Clark Craft brags not to blush but I do not see hardner speed options. Another choice is Marinepoxy. Any opinions on these? I am attaching pictures of the boat repair areas, any suggestions on cloth choice and technique would be appreciated. Kevin
File Type: doc This boat has 3 foam filled fiberglass stringers.doc (209.5 KB, 198 views)
Old 05-03-2006, 01:15 AM
nero nero is offline
Rep: 112 Posts: 624
Blush is not that big of a problem. Water and several paper towels will get rid of it. You can tell if there is blush or not by rubbing your finger on the cured epoxy. Feels waxy, or like grease.
Don't forget to give a scuff sanding between coats if the resin has cured.
non-skid in epoxy resin KMD Fiberglass and Composite Boat Building 14 08-09-2006 09:24 AM
Gel coat/Epoxy fibreglass cloth construction mikeboatman Fiberglass and Composite Boat Building 2 04-29-2006 02:06 AM
Epoxy Laminating Resin JEM Fiberglass and Composite Boat Building 0 11-17-2004 09:45 AM
Epoxy Resin eurotk1 Fiberglass and Composite Boat Building 6 08-27-2004 04:50 PM
epoxy resin? jstephen Wooden Boat Building and Restoration 5 02-23-2004 08:32 PM
