Old 09-30-2006, 01:44 PM
signum signum is offline
Rep: 26 Posts: 24
epoxy with PVC foam
Does anybody works in boatbuilding making the boat hull in fiberglass - PVC foam sandwich using just epoxy not polyester ?
Is that a good method or is too expensive ?
How many layers of laminate should I use in comparison with polyester version?
I know that mat isn't suitable with epoxy just the roving is, is that true ?
Does somebody know a book or guide wich explain more and maybe how many
epoxy laminates should I use ?
Thanks.
Signum
Old 10-03-2006, 10:41 AM
JR-Shine JR-Shine is offline
SHINE
Rep: 50 Posts: 282
PVC foam and epoxy laminates are great, much better than polyester/PVC by any measure (other than price).
The density and thickness of the foam and the lamination depend on many things, not enough info to give any help on that.
Mat CAN be used with epoxy, we do it all the time. You just need to be certain that the mat is compatible with epoxy. Some mat has a binder that is designed to dissolve in polyester, with epoxy it just turns into a gummy mess. Check with your supplier.
I would suggest www.diabgroup.com as a place to start. Also the SP website used to have some good articles, but I have trouble finding them now that they have been acquired by another comany.
Good luck
Joel
www.boatbuildercentral.com
Old 10-03-2006, 03:17 PM
AVMan AVMan is offline
Rep: 10 Posts: 29
SP Systems
FYI.... SP Systems is now under the Gurit name (www.gurit.com)
Old 10-05-2006, 05:19 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
Salut Signum,
What kind of boat are you building?
Epoxy with PVC is no problem, as the others already said.
Most rovings I have seen in your country are very course, and they might not be the best material to use.
Where are you working?
Arriverderre,
Herman
epoxy over PVC foam signum Fiberglass and Composite Boat Building 3 02-19-2006 05:21 AM
building with PVC core foam signum Fiberglass and Composite Boat Building 3 11-26-2005 08:02 PM
Has anyone blown their own PVC foam? Archive Boatbuilding 2 10-08-2004 03:34 PM
Gluing pvc foam core Boatbuilding 4 02-12-2003 03:25 PM
Seal coat on PVC foam Materials 2 01-16-2003 09:46 AM
