Old 12-21-2009, 12:48 AM
Rep: 418 Posts: 777
I've used talc and baby powder in a pinch. Not everyone approves.
Old 12-21-2009, 03:27 AM
magwas magwas is offline
Rep: 47 Posts: 270
[quote=apex1;325771]
Why cant you use a coarse grain filler for glueing???
Sorry if that sounds unpolite, but I have a bit of a problem going through the basics.
And a bigger problem: I´m in bed with pneumonia and 40° C fever.*
/QUOTE]
Well, I am sorry still being at the basics. Can you point me to the relevant information?
I wish you get better.
Old 12-21-2009, 08:27 AM
apex1
The relevant info is in your head already!
A coarse grain filler makes a poor bond and / or a far too high resin consumption for glueing. You need something like flour. I´ve heard some people use plain chalk, but do´nt quote me on that.
For fillets the raw sawdust is a perfect and cheap material, though screening is necessary (your mosquito net might work).
The resin manufacturer "West Systems" provides a good tutorial on his websites
Merry Christmas
and thanks, I am going better a bit!
Richard
Old 01-15-2010, 05:01 AM
nukisen's Avatar
nukisen nukisen is offline
Rep: 114 Posts: 383
Nice thread!
Specially as I am about to almost do the exact same procedure myself. Exept for I am going to us glassfibre rovingnet for strengthen up the construktion.
Hope I will manage to do this.
The more I learn the more I do understand that I do not understand. :)
Old 01-15-2010, 05:09 AM
nukisen's Avatar
Rep: 114 Posts: 383
Maybe we are able to get experience of each other as I do also planing to build a boat out of 3,1mm board plates. I suppose I have to give a first layer before I cover it with glass fibre roving sheet. And also after that I will cover as many layer as it will be smooth and shiny again.
As the epoxy price for me is no longer a big problem I hope to manage to build a boat that is actually useful and works well.
Old 01-15-2010, 02:50 PM
Rep: 3125 Posts: 9,399
Simply put, log onto www.westsystem.com or www.systemthree.com and down load their user's guides. It will walk you through fillers, hardeners, mixing and all the basic stuff.
As a rule there are two types of fillers, fairly smooth and round or fairly rough and long. This describes the physical dimensions of the materials.
The smooth and round items are also light weight and used for fairing surfaces. They have very little, if any structural value and are just used to smooth up surfaces.
The rough and long materials are generally fibrous in nature. These tend to interlock with each other when mixed in resin. This interlocking makes a very strong material when cured. Milled 'glass fibers, shredded cotton, silica, wood flour, etc., if viewed under a microscope are very fibrous and ideal for improving the structural composition of cured resin.
You can use wood chips and/or shredded bits of rope if you want and they'll make good filler materials, though you'll probably have a difficult time controlling the amount of epoxy you use, which is why we use the really fine versions of these fillers. Ideally, the fillers you employ should be in powder form.
Old 01-15-2010, 03:37 PM
nukisen's Avatar
Rep: 114 Posts: 383
THANKS PAR!!
This is very usefull and knowledge increasing information.
Old 01-15-2010, 06:35 PM
kengrome kengrome is offline
Rep: 287 Posts: 719
I bought talc by the sack to use for sandable filler too, it works great. baby powder is usually made of talc, although you should read the label because some baby powder is made of corn starch.
Just add cabosil (fumed silica) to prevent sagging.
My favorite for really strong joints is pulverized limestone, it works great and it is cheap although it is not a lightweight filler. You can buy it at an agricultural supply store. Cement works great too (especially if you cannot find the lime) although it produces a gray filler rather than cream colored or white like the limestone.
These are all mineral fillers that do not absorb epoxy so they are very predictable when mixed with epoxy. One thing though, the lime and cement are hard like rock when cured (because basically that's what they are) so don't expect to sand them easily. Talc is rock too but it's the softest naturally occuring mineral so it sands relatively easily.
Kenneth Grome
epoxy,epoxy, opps flooring epoxy aboyd Materials 5 09-12-2009 02:56 PM
How do I waterproof the drive axle klick Boatbuilding 15 09-24-2008 04:51 AM
Waterproof floor leveling compound? foxmcf Metal Boat Building 4 04-20-2008 08:06 PM
waterproof wall panels for NC house sushi50 Materials 2 02-24-2004 06:52 PM
What to waterproof plywood with? Ward Boatbuilding 14 06-24-2003 09:52 AM
