| Epoxy information source Hi everyone, I'm trying to learn as much as I can about epoxies and the different types, like fast slow resin, the numbers on the various different ones and their meanings, yada yada yada, and was wondering if anyone could point me in the right direction such as where i can learn about this stuff thanks LTW |
| Download the free "users guides" from www.westsystem.com (industry leader) and www.systemthree.com. They'll focus on their products, but you'll get the idea. Then try Paul over at www.epoxyproducts.com or the folks at www.bateau.com for more information. |
| Thanks for your quick responses, just a question for you guys how thick should the epoxy be when bonding the frames? Is a filler/thickener necessary? if so what consistancy should i look for (ketchup, mayo, peanut butter) thanks again LTW |
| For bonding wood a ketchup consistancy usually is desired. Make sure the gaps are not too large, or the epoxy will drip out. If there are larger gaps, fill these with thicker material. Basicly what you want is a good penetration of the wood, for bonding strength (so the epoxy needs to be thin), and the glue between the pieces of wood should be to thick that it does not run out (which means it should be thick). In general the ketchup consistancy does both, especially when made with cotton fibres. (do not put much pressure on the bond, as you run the risk of pressing the fibers dry, impairing the bond). Epoxy basicly is not pressure sensitive. (temporary) screws, weights etc are just there to keep things in place, nothing more. If you are not sure or need to fill large gaps (or need to create fillets) then do a 2-step system: -mix a batch of epoxy -wet out the bond lines -mix fillers (cotton fibres, fumed silica, or whatever) into the epoxy you have left. -use the mix to create the bond. This way you have both well saturated wood, and the epoxy will not sag or drip out. As for working time: buy what you need. For small jobs a fast curing epoxy is fine, but with larger jobs you wished you had more time.
| Favorite Source for Glass/Epoxy/Foam in the USA? | CatBuilder | Materials | 10 | 11-24-2010 09:53 AM |
| epoxy,epoxy, opps flooring epoxy | aboyd | Materials | 5 | 09-12-2009 02:56 PM |
| Block source? | Slainte | Sailboats | 6 | 09-10-2009 01:49 PM |
| Wood source | Secco | Materials | 2 | 06-03-2007 08:03 AM |
| Epoxy information. Maybe | cyclops | Fiberglass and Composite Boat Building | 0 | 10-15-2005 04:41 PM |
