Old 02-06-2006, 10:19 AM
JC47 JC47 is offline
Rep: 10 Posts: 17
Epoxy for Hull Repair
I am repairing major damage to a Stevens 47 sailboat. Orig hull is poly no core. Damage is mid beam to transom, from Deck-Hull joint to 2' below waterline.I calculate about 90 sqft of hull will be cut out and replaced. I was intending to use epoxy. One of the guys in yard suggested using poly because of the sise of the area be replaced and the new and old materials may expand and contract at different rates. I am aware that epoxy has less shrinkage at cure. The cost of epoxy is not a issue. What are your thoughts. JC
Old 02-06-2006, 10:35 AM
Rep: 3125 Posts: 9,399
Epoxy is by far stronger and the product of choice, if cost isn't a major concern. Yards familiar with poly may not want to fool with epoxy for lack of understanding or experience. Poly will do a good job of the repair (in their defense) as the boat is built out of this material, but epoxy is the better goo.
Old 02-08-2006, 11:39 PM
Rep: 10 Posts: 17
Thanks for the info.
JC
Hull Repair devindamarko Sailboats 13 01-23-2006 03:18 PM
repair of holes in hull don1113 Fiberglass and Composite Boat Building 2 08-10-2005 06:52 AM
hull repair eurotk1 Fiberglass and Composite Boat Building 13 04-17-2005 10:53 PM
steel hull repair minstrel Metal Boat Building 4 09-03-2004 12:46 AM
poly vs epoxy manufactured to repair LKJR Fiberglass and Composite Boat Building 4 08-24-2004 02:56 PM
