Old 12-05-2010, 04:27 PM
idkfa idkfa is offline
Rep: 66 Posts: 232
Epoxy gelcoat
Found only a couple of epoxy gelcoats that say UV resistance?...Novalis Topcoat C219 and Resoltech 7060
Guys know of any others and whats been your experience?
SP CR3400 suggest the use of a topcoat, not sure about the Sicomin 715, says "UV stable" on website but not in spec.pdf and "boat production" is not included in recommended usage... But both familiar names...
Also a polyester-epoxy option.
File Type: pdf Scott Bader Polyester epoxy gelcoat.pdf (825.0 KB, 405 views)
Old 12-07-2010, 07:28 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
-any epoxy will yellow over time, so steer away from epoxy gelcoats if possible. However, parts with a shorter life span, or no importance on looks after 15 years, are being made in EP gelcoat if the need is there. (I am talking about canoes, canoe paddles, etc.)
Also parts which are to be painted use EP gelcoat sometimes. (some Mercedes truck parts are EP with EP gelcoat, spray painted after assembly). And many more.
Parts that are not likely to end up in UV (sun) can have EP gelcoat as well, I remind the patient tables for MRI scanners of both Siemens and Philips. The gelcoat is there for hygiene reasons.
-there is a market for UP (unsaturated polyester) gelcoat, which accepts EP as laminating resin, but not in boats. I saw the Scott Bader product in your list. MG Scheufler / Bakelite / Hexion / Momentive (can EP manufacturers please stop changing names??) makes a similar product, called T30 and T35. These are mainly targeted towards the production of small airplanes. Continuously being submerged will damage the gelcoat in no-time, just peeling off the epoxy laminate. In my osmosis tester (distilled water @ 60 degrees C) this stuff peels within a week or 2.
-this leaves you with 1 option: Normal UP gelcoat (for boats preferably ISO-NPG), with a UP or VE skincoat behind it. Use peelply if you can, but be careful with removing it, not to demould the skincoat. My simple tests showed that peelply was an absolute winner, over sanded, non-sanded, sprinkled with short fiber, and sprinkled with sand. I was able to peel all of them loose, after prying loose with a chisel, except the peelply one.
Old 12-08-2010, 03:47 AM
susho susho is offline
Composite builder
Rep: 62 Posts: 66
With what (skin)resin did you test Herman? I have build a few boats with skincoats, VE resin, unwaxed. Haven't had problems with delamination
Old 12-08-2010, 04:29 AM
Herman's Avatar
Resininfusion.info
I tested unwaxed VE resin, hand version. (Polynt Distitron VE100S1T)
During normal use I do not expect delamination, but I was prying the skincoat loose with a chisel and hammer (nothing scientific)
Old 12-08-2010, 04:35 AM
Composite builder
Rep: 62 Posts: 66
nothing scientific, but you've got resutls that show. (normal method at the places I worked, haha.)
Old 12-15-2010, 09:42 PM
Rep: 501 Posts: 1,767
Wouldn't an epoxy gelcoat really be just an epoxy paint and if you had to redo it every 10 years what is wrong with that.
Epoxy gelcoat and non-skid negative idkfa Fiberglass and Composite Boat Building 4 11-30-2010 02:57 PM
gelcoat over epoxy glassman Fiberglass and Composite Boat Building 8 12-13-2005 12:26 PM
NGA Gelcoat over epoxy lamination ducaes Fiberglass and Composite Boat Building 2 03-11-2005 07:12 PM
Fiberglass with west epoxy over gelcoat? bhd Fiberglass and Composite Boat Building 2 03-04-2005 06:13 PM
Gelcoat over Epoxy wet-foot Boat Design 9 08-16-2004 06:58 PM
