A cool epoxy, that goes bad stays at chewing gum stage forever. |
| It's never good advice to cover a bad batch with another batch. You're just bonding to a bad batch which is self defeating. The only good advice in that situation, is to grind down the bad batch, until you're back into good portions of the laminate, then apply more goo. |
| Good advice PAR, but for me you're some 25 Years too late. Believe it or not, that Green F/glass coat made that boat look so good, that somebody stole it, trailer n' all. |
| I use System 3 with the fast hardener and it reliably goes off down to 36 degrees f. Of course, now that it's 70 degrees in the shop instead of 40 i've had some rude surprises!
__________________ Aluminum welding is like sex. The first few times you had at it, you probably could barely please yourself, but with practice and some guidance, you managed to impress one or two prom dates. ~PAR |
| there are marine epoxies that will work and cure at freezing - I use and sell them every winter. That said, could be a mixing problem - off ratio etc, that sort of thing happens to everyone once they get past the beginner stage (it was never the new guys that fell from the rigging in the square rigger days, only the experienced guys) paul oman - progressive epoxy polymers |
Anyone have any speed up tricks? Hope the OP doesn't have the same problem. OH, and another question-- will vinegar, that is soaked in the wood compromise the bond (cedar strips) with a new batch of resin when it is cleaned up? Thanks |
I really dont like working with epoxys at all .they are just a pain in the sit-upon !! stick smelly stuff !!
| Thanks Tunnells!!!! Great Advice!!!! Also. Wear ya glasses!!!! When ya mix !!! ![]() ![]() ....and if I'd been weraing my glasses,. I would jave noticed that the OP is over a month old, so I guess (hope) his batch came out OK... ![]() ANyway, will the vinegar soak into the cedar and mess up a new bond? |
dont know whats your problem but might try to give it some heat, wont hurt me thinks? |
#25
That's helpful, now that's is down. Quote:
I hope you managed to clean off the surface. Sometimes it helps to apply a talk or other powder to the sticky surface so the paper doesn't gum so quickly. Scrape the bulk off, then you know what's next. |
#26
| I am embarrassed to say that vinegar never seems to work for me - and I buy and test by the gallon - and I am in the epoxy business to boot! Guess my expectations for vinegar are just too high. No clue on the affect of vinegar on wood etc. I suspect it is so weak it doesn't do much and that the water in the vinegar is more of a problem. |
#27
| Vinegar is a neutralizer...it doesn't clean worth a crap. It keeps the epoxy from curing while you clean it with something else. Mineral Spirits is about the mildest of the chemicals that actually clean it up. Lacquer Thinner works the best I find but it is pretty harsh. If you have a large gooey mess...Heat and scrape the worst of it off then, if you want to re-epoxy the base material don't use vinegar...go at it with the solvents then let it all evaporate for a good long while. It would be nice if you could heat the area to help with the evaporation but solvents tend to be quite flammable so unless you can pump heat into the area from somewhere else...you'll have to wait for evaporation to take its course. |
#28
| Thanks guys, it is coming off with a scraper, though slowly. Tunnels really does have the best solution. Reminds me of an old Billy Joe Shaver lyric "the hardest thing I learned there is there aint no easy way" |
| Post Curing Epoxy | SeaJay | Materials | 39 | 08-02-2010 06:43 PM |
| Working Time, Pot Life, Open Time, Gel Time... Huh?! | CatBuilder | Materials | 48 | 08-01-2010 03:38 PM |
| Epoxy Gel Time in Relation to Resin Film Thickness Question | ahender | Boatbuilding | 1 | 01-18-2009 10:52 AM |
| post curing epoxy laminate | gary1 | Fiberglass and Composite Boat Building | 3 | 06-09-2007 04:12 AM |
| U V curing | big cat | Boatbuilding | 3 | 10-09-2002 02:04 PM |
