| Epoxy crystallization I just received two 5 gallons buckets of Epoxy from a friend who leave out the region. He bought it last winter and I supposed that he keep it outdoor (our winters are very cold). Yesterday during a big lamination job, the epoxy became to be different. The first 1/3 top was OK but the rest on bucket was full of small crystal. A small part of this epoxy was in my mixed epoxy on my boat (I hope that I will not have problem with that) and I continue with the top of the second epoxy bucket. I can't reach my friend and I don't know where he buy this epoxy. I have no name on the bucket but I know that he buy this epoxy from a big industrial dealer and I'm sure that the epoxy is not old. In the past, I heared some thing about Epoxy crystallization like honey do. Can I use this Epoxy ? How can I stir or filter good epoxy ? Thanks for answer, I'm in a bad situation
__________________ Jean-Francois Blouin PS Sorry for my not so good english Last edited by jfblouin : 09-09-2005 at 06:56 PM. Reason: english error |
| You can try to heat it to around 140 degrees F. I think for about 14 hours. If the crystals desolve and do not come back when the resin cools down, it should be okay for your project. Heat it outside or under a ventilation hood vented to the outside! Might use a ban de euil radiateur for heat. You should do a test cure and destruction test to see if it okay for you. Problem is that you already used part of the resin that was crystalized. This means that if the crystals are disolved back in the resulting compound will not be the same as it was from the factory. Like to gamble? |
| Exactly as Nero says. |
| I heated my Epoxy for all night in a boxe with a small electric heater and all crystal disolved. Thanks
__________________ Jean-Francois Blouin PS Sorry for my not so good english |
| Its like honey in the fridge - warm it up and its back to normal ![]() |
| Easier way for balsa core deck replacement? | pago cruiser | Boatbuilding | 4 | 06-01-2005 07:20 PM |
| epoxy and glass inside and outside? and more | Nordson1960 | Wooden Boat Building and Restoration | 6 | 05-22-2005 09:26 PM |
| Epoxy......how much i need? | {NW}BKUSA | Wooden Boat Building and Restoration | 7 | 01-21-2005 06:14 AM |
| Paint question over epoxy | zember311 | Boatbuilding | 5 | 11-26-2004 03:22 PM |
| Gelcoat over Epoxy | wet-foot | Boat Design | 9 | 08-16-2004 07:58 PM |
