Old 10-26-2011, 12:59 AM
hinemoa hinemoa is offline
hinemoa
Rep: 20 Posts: 34
epoxy bog, or fibreglass resin with red micropheres??
can anyone tell me what is best to use, i have a 12m steel hull but which i have replaced part of the hull and have some inperfections and need to do a lot of fairing and filling etc, what is better to use, the epoxy 2 pot bog or fibreglass resin with red micropheres? if any one has had some experience in the two and could let me know their opionion that would be great, they seem to be both around the same price in 20l capacity
Old 10-26-2011, 01:11 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
Ide buy a welder and fix it properly.
Edit --Oh sorry you said faring didnt you,-- my bad
Old 10-27-2011, 10:09 PM
HakimKlunker's Avatar
HakimKlunker HakimKlunker is offline
t=pc squared ?????
Rep: 111 Posts: 171
What do you mean with fibreglass resin?
Your fairing compound must meet optimal surface conditions or there will be trouble with adhesion.
Boats are flexing, and so your choice of compound must be able to take this, or you will have cracks. If the compound is very thick (dimension - not consistency), this becomes risky; it will be a good idea to shape the steel first. Less fairing is always better.
Old 10-28-2011, 12:43 AM
Rep: 670 Posts: 2,457
Use epoxy for fairing.
Old 10-30-2011, 07:15 PM
Rep: 1493 Posts: 7,447
If you need a lot of fairing, the first step is to heat and hammer the bumps off. Fairing compound should not be too thick.
Old 10-30-2011, 08:05 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
...use epoxy resin with phenolic spheres ..microbaloons (red stuff)...they are made for underwater use. They fill the resin to being a good easily sanded bog and is quite flexible.
Old 10-31-2011, 12:23 AM
peter radclyffe's Avatar
peter radclyffe peter radclyffe is offline
Rep: 576 Posts: 1,066
boero bog is softer to sand than awlgrip
most superyachts would look like kicked welded buckets without it
they speed weld them, unlike shipyards many years ago who did not use filler
there was one superyacht in ........................gio where a guy put his back to the hull and made himself as flat as possible
his mate looked along the hull
and could not see him in the dip and daily distortion that is
prestige yacht for you sir
but the density of the bog/filler may have an affect on the fairers, they launched one multi metre superyacht and found they could not start one of the engines, they went to the stern and after much hole searching and wringing of hands, and probably necks, they discovered one of the exhausts had been filled in with bog, whether this was part of an orchestrated attempt by an eco warrior masquerading as one of the fairing gang in order to cut emissions has never been clearly determined,
its hard to tell which is thicker, the bog or the fairer
Old 10-31-2011, 12:55 AM
Epoxy resin over poly resin ??? lobsterman Fiberglass and Composite Boat Building 5 05-15-2011 07:37 PM
Sealing Epoxy Red Oak Buzzard11 Boatbuilding 15 11-06-2010 07:35 AM
Fibreglass & resin as temp solution to pinhole Conachair Metal Boat Building 4 01-20-2009 04:22 AM
epoxy resin garrick Materials 1 01-16-2009 02:48 PM
Gel coat/Epoxy fibreglass cloth construction mikeboatman Fiberglass and Composite Boat Building 2 04-29-2006 01:06 AM
